What might cause a speedo to be wrong?
Old Feb 12, 2008 | 09:18 PM
Montezumas_Viper's Avatar
Montezumas_Viper
Default What might cause a speedo to be wrong?
Its been wrong since I have had the car. Its about 6mph off at 55 on the speedo itself however, the cruise control is correct so I have to go by that.
Obviously the computer knows the correct speed but the speedo shows it as much slow than it really is. What could cause this?
Old Feb 12, 2008 | 09:21 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Do you have stock rim sizes on the car? If not, the PCM needs to be informed of the wheel size inside the programming.
Old Feb 12, 2008 | 09:34 PM
Montezumas_Viper
The car has z06 rims on in so I don't believe they are any taller only wider. What I'm saying is that the cruise control tells me a different speed than the actual tack.
Old Feb 12, 2008 | 09:46 PM
AMRAAM's Avatar
AMRAAM
Mine differs too, but only by 1 or 2 MPH. The overall diameter of the tire would have to be smaller for it to read faster anyway.
*edit* Nevermind. i see you said it was slower.
Old Feb 12, 2008 | 10:19 PM
dgrant3830's Avatar
dgrant3830
Maybe it needs calibration at a speedometer repair place then. What does the HUD show?
Old Feb 12, 2008 | 11:29 PM
sft316's Avatar
sft316
sometimes drinking to much does this. i try not to let it happen but it happens LOOK OUT!
Old Feb 12, 2008 | 11:32 PM
Mike Mercury's Avatar
Mike Mercury
but if the cruise control (via the DIC) reads correctly... then it shouldn't be a tire size problem.
Old Feb 12, 2008 | 11:58 PM
BlackZ06's Avatar
BlackZ06
I'm sorry, but I'm not understanding what you are saying .....
There is a sensor located at the rear of the vehicle called the Vehicle Speed Sensor (VSS). The IPC uses the output from this sensor to display the vehicle speed digitally (on the HUD) and in analog format (the speedometer). The PCM and TAC also use this same sensor to control the Cruise Control speed.
Are you saying that the speedo displays 55 MPH but if you set the Cruise Control it says it is set for 61 MPH ???
I'd do two things (your profile does not list what car you have so I'm gonna assume you have a HUD) ...... first compare the HUD and speedo displayed speeds (they should agree) .... if they don't, a handheld GPS unit (borrow from friend if you don't have one) will tell you the ACTUAL speed of the vehicle. Then you should have the information to determine if the VSS is providing bad data (unlikely unless your tire sizes are way off) or the IPC speedo is incorrectly displaying data.
If you determine the speedo is displaying the wrong speed, I'd call these guys and see if they can service the IPC.
http://www.paspeedo.com
Old Feb 13, 2008 | 12:12 AM
dgrant3830's Avatar
dgrant3830
I agree
Old Feb 14, 2008 | 01:35 PM
Montezumas_Viper
I've used a GPS unit before and it puts the actual speed 1MPH faster than the speed the cruise control indicates. I do not have HUD so I cannot compare that.
However, the speedometer constantly reads 5 to 7 MPH slower than what the cruise controls reads.
In addition to this I know the TAC is correct because it reads the correct RPM at a real vehicle speed of 70mph
Old Feb 14, 2008 | 01:44 PM
Montezumas_Viper
On a side note this brings up an interesting way one could commit fraud.
Set the pcm for a much smaller tire and reset it before you sell it
Old Feb 14, 2008 | 04:00 PM
robvuk's Avatar
robvuk
Ok, you don't have HUD but you have an average speed display on your DIC. Reset the DIC average speed, then set the cruise for a desired speed, then after a few miles, tell us if the DIC coincides with the speed you set on the cruise and what is displayed on the speedo during that time.
It should be accurate between the average speed and what you set on the cruise. If the speedo is off from those, then the problem is the speedo itself.
Old Feb 14, 2008 | 06:23 PM
andrewboyer5709's Avatar
andrewboyer5709
Default speedo
another possibility is that the wire that hooks up to the back of the speedo may be loose, or not connected correctly, which in turn causes the wrong speed to be displayed... my 2 cents...
Old Feb 20, 2008 | 12:32 AM
Montezumas_Viper
I've done this an have come up with almost the exact same average speed as my cruise speed so the computer definately knows the correct speed. It must be the speedometer itself, what do I do now?
Old Feb 20, 2008 | 12:45 AM
leviathan125's Avatar
leviathan125
Does it have aftermarket face gauges? Maybe the speedo pointer was removed and when it was put back on it wasn't replaced in the exact correct position?
Old Feb 20, 2008 | 02:06 AM
BlackZ06's Avatar
BlackZ06
I would call these guys and see if they think they can fix it .....
If they can, you will need to remove the IPC (the unit that includes the gauges), pack it well, and ship it to them.
Otherwise, you will need a new IPC, and again paspeedo can program the new IPC with your current odometer reading. A dealer can order a new IPC, but they will have to send it out to get the odometer set as dealers can't do that, the IPC has to have a special "tool" used to change the odometer.
To What might cause a speedo to be wrong?
