Service abs and traction control light
Old Feb 14, 2008 | 01:38 AM
90 zr-1 206mph's Avatar
90 zr-1 206mph
Default Service abs and traction control light
After hitting a bump my service light would come on and go out after I restarted the car. Only after hitting a good bump the light would come back on, and now comes on no matter what which means more than likely a sensor probably on the wheel came loose. I went to autozone and used the scanner to find a code and it didnt come up with any. What is the trick to pull codes from the dash? Has anybody had this come up from hitting a bump and found something to be loose?
Old Feb 14, 2008 | 01:52 AM
BlackZ06's Avatar
BlackZ06
Go here for instructions on how to display the codes ....
https://www.corvetteforum.com/techti...D=26&TopicID=1
Old Feb 15, 2008 | 09:11 AM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
With the key on and doors closed, hold down #4 and within 10 seconds hit #1 4 times for your codes.
Follow the wiring to the sensor behind each rotor and make sure sensors didn't move. Also check wiring at the plug near the frame and make sure it didn't come un-clipped.
Old Feb 15, 2008 | 02:02 PM
Bill Dearborn's Avatar
Bill Dearborn
What year car do you have? Do you have the active handling option?
Bill
Old Feb 15, 2008 | 10:08 PM
BLOWNBLUEZ06
Here is a tutorial on checking out the cause of the 1214 code. I expect that's what you'll find.
This is from ABSfixer.
http://forums.corvetteforum.com/show....php?t=1941808
To Service abs and traction control light
