misfiring under a load?
Old Feb 15, 2008 | 02:00 AM
12leavu's Avatar
12leavu
Default misfiring under a load?
here is exactly what is going on. the car runs fine at all times idle,WOT,city driving, ect...except in overdrive at low rpms..1200-1600 if i lightly press the gas is starts busting up. sometimes pretty bad, sometimes you can barely notice.(doesnt matter engine temp).. it hasnt thrown a code yet. i first changed the plugs and plug wires with no luck. then i installed new o2 sensors. no luck there either. any suggestions?
Old Feb 15, 2008 | 09:58 AM
12leavu's Avatar
12leavu
bump
Old Feb 15, 2008 | 10:30 AM
FASST LN's Avatar
FASST LN
Just spitballing here, but maybe it could be one of your coil packs or injectors.
I would try running a bottle of Techron fuel injector cleaner through your gas tank first, since that is easy to do and only costs about $7.
And you buying premium fuel? Curious if someone from the board with a scanner is near you and could check your fuel trims under this low rpm scenario to see what is happening.
Old Feb 15, 2008 | 12:39 PM
12leavu's Avatar
12leavu
yes to premium fuel. im about to purchase hp tuners , so maybe i can diagnose the problem when i get it. i did the injector cleaner, i will run that tank empty and see if it helps
Old Feb 15, 2008 | 02:22 PM
Todd157k's Avatar
Todd157k
Banned Scam/Spammer
any misfire codes? or codes at all?
did you do anything to the car before this started?
Old Feb 15, 2008 | 03:00 PM
12leavu's Avatar
12leavu
no codes as of now, been a week... actually i cleaned and oiled my k&n , so i was considering it to be a bad MAF. i do beleive however that i let it dry enough. also was running 100 octane the same day it started, (nothing new, i do everytime i go to the track i mix a 100 octane.) i went to the track, made one pass, left and drove around town all day. about 70 miles later it developed the misfire.
Old Feb 17, 2008 | 05:42 PM
12leavu's Avatar
12leavu
well i replaced the fuel filter/regulator. it was definitly clogged up somewhat. when i installed and cranked the car again i was getting the full 58 psi. instead of the previous 50 psi. also the pressure is still bleeding off to 0 psi, but now it is taking an hour to do so instead of 15 mins. the car is still misfiring under low rpm load. i assume the pump may be bad, a bad injector, or possibly the check valve between the tanks...however i dont believe the bad check valve would cause the misfire/studder.
Old Feb 17, 2008 | 09:22 PM
aleadfoot's Avatar
aleadfoot
Check your spark plug wires one might have backed off
Old Feb 18, 2008 | 01:46 PM
12leavu's Avatar
12leavu
that was the first thing i checked. ive even switched MAF meter with another guy, still have problem.
To misfiring under a load?
