Losing reverse?
Old Feb 15, 2008 | 11:16 AM
yakisoba's Avatar
yakisoba
Default Losing reverse?
Having a hard time getting the Z into reverse. Transmission teardown time? If so, what else to do while the car is apart?
Old Feb 15, 2008 | 11:32 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Always do the shifter alignment first. This will generally help if not fix most issues.
Old Feb 15, 2008 | 11:35 AM
99C5x's Avatar
99C5x
Default =d
Well that sucks that you are having trouble! IMO I'd probably look at my clutch setup. You may already have a nice setup?
Old Feb 15, 2008 | 11:36 AM
Tigershark3's Avatar
Tigershark3
I'd suggest before you tear anything down that you change the transmission fluid. Getting the old stuff out and replacing w/ new could make a difference. I went with the GM lubes but that's just me as I had heard that '99 MN6 have syncros that don't do well with synthetics. Check your manual but you'll also most likely need about 8oz of anti-slip additive.
Old Feb 15, 2008 | 12:14 PM
yakisoba's Avatar
yakisoba
Thanks. I'll check into shifter alignment.
The trans fluid has not been changed this year, and we're three track events in. I'll do that as well.
Clutch is good, no issues there. It's stock though.
Old Feb 15, 2008 | 12:24 PM
BERGN8R's Avatar
BERGN8R
I'm having a hard time getting to reverse as well. I need to use both hands. I played with the adjustment and it made it better but still difficult. I emailed RPM Transmissions and they suggested checking the lockout solenoid. Haven't looked into it yet, waiting for snow to melt here. It happened at the end of season last year. I was at the strip and after a run had trouble backing into my pit spot.
Old Feb 15, 2008 | 01:46 PM
jedblanks's Avatar
jedblanks
A little trick I learned long ago was to push clutch in, put shifter into third (since its the easiest forward gear) then take out of third and slide over and into reverse. Goes in easier. Done this since 2000 on various LS1s, seems to help.
If you have a real problem it may not help, but try this before trying anything else.
Old Feb 15, 2008 | 07:08 PM
Gray Ghost GS's Avatar
Gray Ghost GS
"AlohaC5" Senior Member
The first sign of my transmission dying was the loss of my reverse gear, then came 5th gear....if you track your car, I highly recommend getting an RPM Level 4 Transmission - worth the investment. Mike
To Losing reverse?
