Which head bolt set should I use?
Old Feb 16, 2008 | 10:03 AM
coanan's Avatar
coanan
Default Which head bolt set should I use?
Never tore a LS engine apart; I’m getting the parts together for a H/C change and don’t know which head bolt set to use. There are two to choose from. I'm installing 243 heads on a 99 LS1 block. Thanks
Old Feb 16, 2008 | 10:54 AM
Brad@RevXtremeAutoSports's Avatar
I would use ARP bolts at least and use the ones for 98-2003. There was a design change in the block starting in 2004. Plus you can reuse them.
134 dollars well spent. part no: 134-3609
Old Feb 16, 2008 | 11:24 AM
coanan's Avatar
coanan
My pockets aren't that deep.LOL I mean there are two GM sets. One set 20 long and 10 short and the other set 16 long, 4 med, and 10 short. Which one is the 97-03 set.
Old Feb 16, 2008 | 01:59 PM
vettekidc5's Avatar
vettekidc5
16 long, 4 med, 10 short is 97-03
Old Feb 16, 2008 | 02:28 PM
coanan's Avatar
coanan
That's what I needed to know. thanks
Old Feb 16, 2008 | 06:46 PM
yep. soryy not getting back to ya, working on my own major project.
Old Feb 16, 2008 | 08:34 PM
08 ATOMIC-Z's Avatar
08 ATOMIC-Z
You need to see which set is installed in your engine. I just went through this with my 2004. The change was in Jan of 04 but you will not be sure till you see the bolts.
To Which head bolt set should I use?
