H pipe vs. X pipe exhaust
Old Feb 16, 2008 | 10:05 AM
lodilobo's Avatar
lodilobo
Default H pipe vs. X pipe exhaust
I recently bought a '01 Z06 that has long tube headers, but for some reason, the H pipe was kept, rather than going to an X pipe system. The car is fairly stock except for the headers, a cam upgrade to the "02 LS6, and modifications to the 243 heads. Does anyone know how significant the switch to an X pipe would make in rwhp? I am planning on modding to approx. 550 rwhp, probably a nice cam, possibly a supercharger. I would just switch to an X pipe, but the shop that did the work on this car, a very well known Corvette shop, welded everything. I mean, everything.....no bolt up to the H pipe at the header junction. While I always do my own modifications, welding exhaust systems is not one of my strengths. I really hate to rely on other people to work on my car, so my inclination is to keep the exhaust as is. Any input on this will be apprectiated. By the way, the car dyno'd as is at 382 rwhp. I felt that it should have been around 400 - 410. Could the H pipe be restricing it to that extent?
Old Feb 16, 2008 | 10:25 AM
vettekidc5's Avatar
vettekidc5
Im gonna wait for others to chime in about the X pipe.. Im not sure Im wondering my self..
I got a friends 01 z06 with the LG headers and x pipe, My only complaint is is sounds kinda raspy at low- mid rpm..
I know in my mustang days there wansnt really any reall gain to X or H they made about the same.. But they had different sounds, Im more fond of the H sound.
385 HP to the wheels is very good. you wont get 400-410 hp never on just a header swap. Since u upgraded the "02"ls6 only made 405 at the flywheel, The 01 made 385.
if i remember right most of them are dynoing in at arround 340-350HP. So if thats correct you gained about 30-35 HP which is not shabby.
Old Feb 16, 2008 | 11:41 AM
Gordy M's Avatar
Gordy M
The X pipe will add more HP with a proper tune, however where you place the X pipe determines how much it will help. Extensive testing has shown the best results are right after the collector. The further down stream the less the results. If you are running cats, place it before the cats. On a head and cam car it should be worth 25-30 flywheel hp.
Old Feb 16, 2008 | 12:43 PM
VIPERBLUELX's Avatar
VIPERBLUELX
Ain't no way an X-pipe is gonna add 25-30 hp over an H-pipe.
Old Feb 16, 2008 | 12:48 PM
Got uid0's Avatar
Got uid0
St. Jude Donor '17
2x2 xpipes used right at collectors are different from the x pipe that replaces your h-pipe
x-pipes that replace the h-pipe change the sound to a softer note 2-3hp maybe
Old Feb 16, 2008 | 01:11 PM
lodilobo's Avatar
lodilobo
Well...I guess this is the reason I asked. There are a few different opinions on this. On my '99 Corvette, I installed an X pipe along with catbacks, when I installed the lg headers. I stopped at the Corsa plant here in Ohio...it's 5 min. from my shop. When I asked the question "why should I go to an X pipe?" the guy brought out a cut off section from a stock Z06. I was amazed that when the exhaust gets to that H area, the size of the hole shrinks down to maybe about the size of a nickel...maybe slightly larger. Being that far down the line, I am not sure if it really is that big of a factor, though.
Old Feb 16, 2008 | 02:32 PM
Gordy M's Avatar
Gordy M
The H pipe is a 5/8" hole located past the cats and is used for sound purposes to balance exhaust pressures. An X-Pipe is a 2.5 or 3" crossover allowing the exhaust to flow faster. The closer the X is to the heads the easier it is for it to draw the exhaust out of the heads leaving better makeup of air/fuel burn.
Old Feb 16, 2008 | 03:08 PM
LTCHAPPA's Avatar
LTCHAPPA
The x pipe will give you a smoother exhaust flo. Maybe a 5 hp gain over the H pipe.
Old Feb 16, 2008 | 09:15 PM
HT1663WB's Avatar
HT1663WB
I had the X Pipe and Z06 cat back. I went to the full Z06 exhaust including H-pipe. Seat of the pants, I would say the H Pipe feels better. I do get some popping on decel but I think it feels and sounds great.
Good Luck
Old Feb 16, 2008 | 11:15 PM
Got uid0's Avatar
Got uid0
St. Jude Donor '17
x-pipes that replace cats are a different breed compared to the x-pipe corsa sells to replace your h-pipe.
Old Feb 17, 2008 | 12:44 AM
TheRadioFlyer97's Avatar
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
you loose the "burble" and the popping sound with backflow. You will get a power gain, but it's minimal at best.
Old Feb 17, 2008 | 02:24 PM
XtremeVette's Avatar
XtremeVette
Original Founding Member!
Cruise-In 1, 3, 9. 10 & 11 Veteran
Default more hp......I dont' believe it.....
I would love to just see a dyno graph on this, cause for the 3-5 hp that some people are saying you gain....I think its all smoke and mirrors.....sorry guys....gotta call
Lets see a dyno graph of 2 identical systems with the only difference being X or H pipe.
Only thing I have seen proven is you get a different sound from the x pipe.
Old Feb 17, 2008 | 04:11 PM
Got uid0's Avatar
Got uid0
St. Jude Donor '17
I saw a major improvement at the track it of course came from a combination of changes and that is how it usually works.
Otherwise stock a4 fresh f1 super car 295 tires, cold air, and x pipe and corsa indy
12.9
Dropped 3-4 tenths off my average run. Not sure if it was purely the tires alone or the combination.
Old Feb 17, 2008 | 04:32 PM
robvuk's Avatar
robvuk
If it was that easy to gain 5 hp, GM would be all over it. It costs nothing for the factory to install an X pipe instead of an H. It is for the sound only as equipped from the factory. The X pipe MAY add 1hp if you are using equal length headers and a tune.
Old Feb 17, 2008 | 06:34 PM
4 KRUSIN's Avatar
4 KRUSIN
Here's a web site that shows some real #'s.
http://www.vetteweb.com/tech/0307vet...nfo/index.html
Dave
Old Feb 17, 2008 | 07:25 PM
slowtealz28's Avatar
slowtealz28
I think of of the sponsoring shops should man up and dyno a setup w/an h-pipe 3-5 times to get an average baseline, and then in the same day swap the H w/an X and re-dyno 3-5 times and average
Old Feb 17, 2008 | 08:53 PM
HUMVET51's Avatar
HUMVET51
I would look into the Bassani X-pipe. Its less restictive than the Hpipe and its a slipfit design (no welding). I dont know about a 25-30 hp increase. About 8-10 is more likely.
To H pipe vs. X pipe exhaust
Old Feb 17, 2008 | 10:06 PM
robvuk's Avatar
robvuk
Dave
So this guy claims 13.9 hp for the entire exhaust, including the Xpipe and tune. Just proves that the Xpipe alone does little or nothing.
Old Feb 17, 2008 | 10:59 PM
Got uid0's Avatar
Got uid0
St. Jude Donor '17
So where did it mention anything about a tune again? Just admit when you are wrong and move on lol
The reason an X-Pipe crossover works better than an H-pipe crossover isn't more flow because of volume, but more effective use of exhaust gas velocity. Exhaust gas (or air) has surface tension, and flows much like liquid would through the same pipe system.
Old Feb 17, 2008 | 11:14 PM
robvuk's Avatar
robvuk
I'll be happy to admit I'm wrong when someone shows evidence that an Xpipe alone will yield 8 or 9 hp at the wheels OR the crank. With or without an additional tune, he gained 13.9 INCLUDING the catbacks.
Gee, if GM only knew that in 2001 they didn't have to change the injectors and intake manifold to bump from 345hp to 350hp! All they had to do is add an Xpipe and they could have got 354hp! Boy are they ever a bunch of idiots there.
