three problems.
2) when accelerating normally from about 45-48mph i get a nasty stutter and hesitation like it's missing or fouled out. i took it for a check up and they didn't find any codes but said they saw a plug wire arcing out and suggested all new plugs, wires, etc. it seems to behave normally under any other circumstances, even if i nail it at much slower speeds.
3) the alarm function on the keyless allows me to set the alarm but it only pyhsically locks the passenger door. do i have something set wrong? i've had the car about a year but i'm not sure if this is a new
or i just never noticed it.
any body have any ideas? thanks!
mike-ssi ......
In reverse order ... you most likely have a bad solenoid in your DCM ... go here on instructions on diagnosing/fixing the problem ....
http://forums.corvetteforum.com/show....php?t=1606865
For your first two problems .... new plugs and wires ......
Order and install .....
AC Delco Iridium 41-985 spark plugs. They come CORRECTLY pre-gapped at 0.040 inches.
GM Performance Parts wire kit - contains 8 wires in the kit. GM part number is 12495519
You can get the spark plugs from almost any Auto store (Napa, Pep Boys, AutoZone ....) and many can also get the wires. Otherwise you can order the wires from supporting vendors such as
http://www.gmpartshouse.com
or
http://www.gmpartsdirect.com
Also, fill out your info on year of Vette and other info, like its an automatic, and the general area where you live. This will help people to help you.
The starting problem could be IAT sensor not working right. The hesitation sounds like an issue with down shifting. But, having any codes that are set will tell you more specifically whats going on.
