DIC won't come on....
Old Dec 4, 2001 | 08:36 PM
Naylin's Avatar
Naylin
Default DIC won't come on....
I think I've messed up big time... Was trying to sort out column lock bypass and removed and replace fuse whilst engine running. Car cut out and now DIC wont come on, and car won't start..... any suggestions...
Old Dec 4, 2001 | 09:14 PM
Viprklr's Avatar
Viprklr
Default Re: DIC won't come on.... (Naylin)
Make sure all fuses are in their proper places and that none of them are broken. Check them closely. If everything looks good then connect the battery back and see what happens. Sorry to hear you are having so much trouble with your column lock. Keep us informed as to the outcome.
Old Dec 4, 2001 | 11:19 PM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
Sorry to hear!:confused:
If your DIC is dead you are in trouble. The only time, I can recall a dead DIC, was when the battery was disconnected. If this is not the case, only a trip to the dealer can restore your DIC.
[Modified by wallstAL, 7:22 PM 12/4/2001]
Old Dec 4, 2001 | 11:23 PM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
If your DIC is dead you are in trouble. The only time I can recall a dead DIC was when the battery was disconnected. If this is the case, only a trip to the dealer can restore your DIC.
Old Dec 5, 2001 | 12:13 AM
luvinc5's Avatar
luvinc5
Default Re: DIC won't come on.... (wallstAL)
you gotta admit this is a funny line-
:D :D :lol: :lol:
Old Dec 5, 2001 | 02:28 AM
Naylin's Avatar
Naylin
Default Re: DIC won't come on.... (luvinc5)
guess it is funny... but there isnt a dealer here in New Zealand so i'm in trouble..
Old Dec 5, 2001 | 04:08 AM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
I think you have a real problem, you might have to remove your DIC and mail it in to GM or a dealer (turn around). :( :( :(
Old Dec 5, 2001 | 04:50 AM
6699's Avatar
6699
Double check ALL fuses, restore original hook up for column lock, disconnect battery for 1/2 hour, connect battery, re-program your keyless entry, lock and un-lock with remote, and try again.
Good Luck!
Mikael
Old Dec 5, 2001 | 05:57 AM
Naylin's Avatar
Naylin
Default Re: DIC won't come on.... (6699)
thanks... will do
Good Luck!
Mikael
Old Dec 5, 2001 | 08:03 PM
Naylin's Avatar
Naylin
Had to get the car onto a salvage truck and taken up to Auckland to the guys who did my Right hand drive conversion (about 1 1/2 hours away). They changed a few fuses and believe it or not the car is running perfectly.
Old Dec 5, 2001 | 08:09 PM
HP-GURU's Avatar
HP-GURU
Man you are having problems... :cuss
Old Dec 5, 2001 | 08:21 PM
Naylin's Avatar
Naylin
Default Re: DIC won't come on.... (HP-GURU)
You can say that again....
Old Dec 6, 2001 | 12:44 AM
shockwave's Avatar
shockwave
Glad you solved it though...
Old Dec 6, 2001 | 03:21 AM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
Good out come, next time be careful.
Old Dec 6, 2001 | 03:42 AM
Avanti's Avatar
Avanti
Glad it worked out. Don't disconnect electrical "thingies" of any sort while energized unless the shop manual tells you to for a specific reason. Microprocessors and related circuitry are NOT forgiving in this regard. I image a right-hand conversion on today's vehicles is an interesting proposition.
BTW, turning 54 y.o. this month I must confess I sometimes have the same problem, even my dealer's no help! Won't even talk to me about it. :lol:
All the best :yesnod:
Old Dec 6, 2001 | 09:15 AM
Tom/99's Avatar
Tom/99
Good to hear that all is working again. :chevy
To DIC won't come on....
