Replace antifreeze
Old Feb 20, 2008 | 11:44 PM
Bill Daly's Avatar
Bill Daly
Cruising
Default Replace antifreeze
I have a 1998 Vett. I bought it used with just 6000 mi on it back in 1999.so I've had it for a while.In that time I've had a couple small problems,but thanks to all of you in forum they have stayed small.I only have 30,000 mi on it now.I know thats not a lot but I would like to change the antifreeze just because its ten years old.I am a maint.man by trade, but I've never changed antifreeze on a newer car before, so I would like to know how to do this before I start. Thanks.
Old Feb 21, 2008 | 02:13 AM
*FAÇADE*'s Avatar
*FAÇADE*
PHOTOSHOP SPECIALIST
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16
Hey Bill, Congrats on your '98 Vette & Welcome to the Corvette Forum!
You might want to post your question on changing the antifreeze in the "C5 Tech" section of our forum - our knowledgeable members there will be glad to help you.
http://forums.corvetteforum.com/foru...ysprune=-1&f=1
In case you need an 1998 Owner's Manual, here's a link to the PDF version:
https://www.mygmlink.com/pdf/go2cont...98corvette.pdf
Take care!!
Old Feb 21, 2008 | 02:57 AM
traindude's Avatar
traindude
Welcome aboard Bill!
Excellent info from FAÇADE-C6!
Old Feb 21, 2008 | 03:08 AM
C5R USA's Avatar
C5R USA
From: Ideals are peaceful...History is violent...St.Charles, MO.
C5 of Year Winner (appearance mods) 2019
St. Jude Donor '08-'09-'12 thru'22
Welcome to the Forum!!!
Old Feb 21, 2008 | 06:28 AM
BlackZ51Vett's Avatar
BlackZ51Vett
Welcome aboard. Enjoy !!!!
Old Feb 21, 2008 | 10:28 AM
bighank's Avatar
bighank
Default dexcool DOESN'T LAST 10 years
Change it NOW. Flush iit well. Plain water till it runs clear. NO CORROSIVE FLUSH ADDITIVE. Search on dexcool and you will see MANY problems on here. BIGHANK
Old Feb 21, 2008 | 11:05 AM
lucky131969's Avatar
lucky131969
Yep, it's time to change it alright. It's about 5 years past due.
Old Feb 21, 2008 | 02:52 PM
ccrazor's Avatar
ccrazor
Welcome to the forum..
Old Feb 21, 2008 | 03:24 PM
hotwheels57's Avatar
hotwheels57
In C5 Tech, click on search this forum (in the red banner) using keywords "antifreeze" or similar. You'll find plenty to read.
Many elect to continue to use oem type DEXCOOL (or similar orange extended life products) for it's friendliness to aluminum (and the environment, animals, etc). Past issues with it were related to poorly maintained coolant systems, gaskets and GM added tablets...since improved upon by GM.
If you chose to switch to green, you'll have to make more frequent annual changes.
It's your car to do with as you please.
BTW, I found this which might be helpful to you...
http://forums.corvetteforum.com/show...ght=antifreeze
Old Feb 21, 2008 | 04:50 PM
FKING1's Avatar
FKING1
Anti-Freeze should be changed every 5 years. I took my 2000 to a dealer who chemically flushed the system and refilled. I know this is an expensive route but it gave me peace of mind.
Old Feb 21, 2008 | 04:58 PM
hotwheels57
...and that's the only practical manner in which to completely remove the old antifreeze before refilling with new orange (or green)...
Old Feb 21, 2008 | 05:26 PM
SilverRaven's Avatar
SilverRaven
Default AMS OIL Antifreeze
I put the gold stuff from AMS Oil in the vette last year. My car is an
'01 Z that I bought in Oct of '06. I was not sure how old the coolant
was. When I tested the old coolant it was still good. I decided to
change it anyway. The AMS Oil stuff says it is good for 7 years and is
environmentaly freindly. Good luck!
Rob
Old Feb 21, 2008 | 08:26 PM
Bill Daly's Avatar
Bill Daly
Cruising
Thanks for the help.I have the owners manual, and I will study it a little closer.You have a great vette day. Thanks again Bill.
Old Feb 21, 2008 | 08:32 PM
Bill Daly's Avatar
Bill Daly
Cruising
Thanks I'll change it.
Old Feb 21, 2008 | 08:57 PM
Bill Daly's Avatar
Bill Daly
Cruising
Thank you.
Bill Daly's Avatar
Bill Daly
Cruising
Thank you
Old Feb 21, 2008 | 09:00 PM
Bill Daly's Avatar
Bill Daly
Cruising
Thank you
To Replace antifreeze
Bill Daly's Avatar
Bill Daly
Cruising
Thank you
Old Feb 21, 2008 | 09:02 PM
Bill Daly's Avatar
Bill Daly
Cruising
Rob
Thank you
Old Feb 21, 2008 | 09:07 PM
Bill Daly's Avatar
Bill Daly
Cruising
[QUOTE=Bill Daly;1564208057]Thanks I'll change it
