got a bouncing tach
Old Feb 22, 2008 | 12:47 AM
z06801's Avatar
z06801
Default got a bouncing tach
I have a bouncing tach. Could it be a ground? where would it be if it was.
Old Feb 22, 2008 | 02:41 AM
BlackZ06's Avatar
BlackZ06
The IPC has a single ground ... so all of your gauges would "bounce" together if the ground was bad.
The IPC receives the engine speed signal on a white wire (circuit 121) which is pin A17 on the wiring connector to the IPC.
Does your car have a HUD ... If so, is the tach dispaly on that correct ?? If itt is then your IPC needs to be serviced as the tach is bad.
http://www.paspeedo.com can service it.
Old Feb 22, 2008 | 11:54 AM
z06801's Avatar
z06801
Thank's for the input. 01 z06 so no HUD, and it is bouncing independent. it is works normal most the of the time, then it will take a couple of hops. engine stays smooth.
Old Feb 22, 2008 | 01:46 PM
bcampbe7's Avatar
bcampbe7
Could it be an alternator going bad?
I know it is not the same vehicle but when a bouncing tach occurs in a Land Rover DII it usually means that the alternator is not performing 100% as is on it's way out.
Old Feb 27, 2008 | 09:05 PM
Fartpipe's Avatar
Fartpipe
Interesting, I had/have this concern sometimes at the track. As the car rev's quickly in 1st gear it bounces a little on the way up then its fine.
To got a bouncing tach
