65,000 miles - Preventative Maintenance?
Old Feb 25, 2008 | 04:16 PM
JCrouse's Avatar
JCrouse
Default 65,000 miles - Preventative Maintenance?
I've hit the 65,000 mile mark in a 2000 coupe (6 speed) and the car still runs well. Are there any good ideas for preventative maintenance? I was thinking maybe seafoam followed by an oil change and new plugs? Any suggestions on plugs, i did a search but didn't find anything meaningful unless i have NOS, which i don't, just a Blackwing and B&B exhaust.
Any quick fixes of things that are known to start dying around now?
I know this is a really general post, but i feel like i should be doing something ~60,000 or so.
Old Feb 25, 2008 | 08:29 PM
foggy's Avatar
foggy
Plugs, wires, flush coolant - replace with 50% Dexcool mixture.
Replace brake fluid. Power steering fluid. Trans fluid needs to be changed, Differential serviced.
Check belts real closely. REplace coolant hoses if still original.
That's the stuff I do about every 30K or so.. 99,000 still strong.
Old Feb 25, 2008 | 09:15 PM
Plasticfan's Avatar
Plasticfan
I did most of this at the 70k point. Just seems like good maintenance to me. As far as plugs and wires go, you'll get lots of opinions here. I used the GM iridium plugs and GM red wires. They work just fine for me. Be prepared for a battle w/the plug wires. Mine seemed like they were welded to the plug. I finally just got aggravated and ripped them to shreds. Don't forget dielectric grease on the new wires.
Old Feb 26, 2008 | 10:44 AM
FASST LN's Avatar
FASST LN
At 65k miles, assuming you're not having any problems with your current plug and wire setup, I would leave them alone.
Go ahead and inspect them, break the plugs loose and apply some anti-seize, but otherwise if its not broke, don't mess with it.
No point in spending money when you don't have too. Especially when it wouldn't net you any better results.
I agree with all of the fluid and air filter changes. Possibly change the fuel filter too if its never been done.
If you have money burning a hole in your pocket, you could always replace/upgrade your existing shocks as I'm sure your OEM set is quite 'tired'.
To 65,000 miles - Preventative Maintenance?
