kooks Header install...Anything i should know?
Old Feb 29, 2008 | 10:38 PM
SICVENM's Avatar
SICVENM
Default kooks Header install...Anything i should know?
well im going to install my 1-3/4" kooks long-tubes tomorrow and would like to know if there is anything i should know or look for? I also heard the kooks are harder to install
thank you
Old Feb 29, 2008 | 11:03 PM
byte_me's Avatar
byte_me
I had the older versions installed on my 97 a few years ago (I read somewhere on the forum they made adjustments to fitment since mine)- great headers! The installer did have to jack the engine up on each side to get them in though...they told me that these although great headers were the most difficult to install.
once installed I can honestly say that I loved every minute of them!
Good luck!
Old Mar 1, 2008 | 12:30 AM
AMRAAM's Avatar
AMRAAM
i installed mine with no issues, but I put them in with the heads off. Made it very easy. i did have to loosen the pass motor mount and lift the engine slightly to go between the starter and the AC line. i am also not able to line up the bracket that bolts up to the bell housing, but i haven't been able to loosen everything up to adjust it a bit.
Old Mar 1, 2008 | 08:02 AM
Blow Torch's Avatar
Blow Torch
What they both said
I'm not sure what "verson" they were, but they were the hardest headers I've ever installed (and I put them on nine different vettes including a big block C3. The SSautocrome for my wifes car were NOTHING to install next to these! That being said, they're just headers so it will only be agravating, not impossible.
I had to jack the engine, remove starter, remove oil filter along with all the top items (alternator etc) and wound up using a big . The passenger was fairly easy, the drivers were the hardest. If I were you, I would remove water temp sender in the front drivers side head, as they are easily broken
I don't mean to make you dread the install, becase some guys don't seem to have as much trouble. Maybe they're made in differnt jigs and one of the jigs is off Anyway expect to spend a few hours, and if they're easier, (like my vararam install turned out to be) then you wil feel great!
You're going to love the power increase either way!!
Old Mar 1, 2008 | 10:36 AM
bayarea's Avatar
bayarea
make sure you have some beer to help out.
Old Mar 1, 2008 | 11:19 AM
BlackZ06's Avatar
BlackZ06
thank you
You show Sacramento on your profile ... Long Tube headers are illegal in CA ... you may have a problem at your next smog check ....
Old Mar 1, 2008 | 11:27 AM
Tsab's Avatar
Tsab
Plan for an all day affair. Good Luck.
Old Mar 1, 2008 | 12:54 PM
SICVENM's Avatar
SICVENM
And so is your intake on your car, any modification to a car in ca is illegal. mufflers even. plus im not to worried i have 2 friends that can get it to pass
Old Mar 1, 2008 | 02:57 PM
BlackZ06's Avatar
BlackZ06
You asked "if there is anything i should know or look for" .....
I just pointed out a "fact" .... if you have a way around this problem ... good for you .....
Old Mar 1, 2008 | 03:01 PM
briann510's Avatar
briann510
Mufflers are not an illegal change on cars in California UNLESS they exceed the maximum decibel level (even though the actual law reads like it is). Some cops in the past and even now will write tickets for changing catback exhaust but it doesn't hold up in court (personal experience several times on this). There is always some smog tech that will smog anything no matter whats been done to it or just register the car in a non smog check zip code (and there are many zip codes in California that still don't require a smog check ever unless car is sold).
Old Mar 2, 2008 | 09:21 PM
saw22's Avatar
saw22
Make sure the front O2 sensor wires don't end up dangling on the headers and burning up.
To kooks Header install...Anything i should know?
