Clutch Bleeding
Old Mar 1, 2008 | 04:40 PM
BillFRC's Avatar
BillFRC
Default Clutch Bleeding
Just wanted to know if when you folks bleed your clutch - when you bring pedal to floor and hold - then open bleed valve - then close bleed valve - then release pedal - does the pedal stay on floor or will it come back up on its own. Mine will not come up on its own - you have to help it back. After I help it back it reacts ok. Is this normal ?
Old Mar 1, 2008 | 05:57 PM
Slow Z06's Avatar
Slow Z06
Put a lil pressure on the pedal. Open the bleeder and while the pedal is going down, yet before it stops, close the bleeder.
Rinse and repeat as necessary
And yes, thats normal
Old Mar 1, 2008 | 06:32 PM
lionelhutz's Avatar
lionelhutz
I just bled mine and it came back up after closing the bleeder. I guess it could depend on the system to some extent. I was under the car so I didn't get to feel the pedal.
Peter
Old Mar 1, 2008 | 06:42 PM
DRR's Avatar
DRR
Remote bleeder and a Mity Vac. 1 person job.
Old Mar 1, 2008 | 10:17 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
I use a remote bleeder. Petal pops right back up.
Old Mar 2, 2008 | 08:11 AM
BillFRC's Avatar
BillFRC
I use a remote bleeder and pedal stays down. strange huh some come back some do not.
Thanks for input.
Old Mar 10, 2008 | 08:00 PM
illenema's Avatar
illenema
Default Bleeder
will Do
Old Mar 10, 2008 | 08:20 PM
ericdwong's Avatar
ericdwong
Did this last night- pedal stayed down. It feels fine driving it today though. The clutch fluid was nasty.
Old Mar 11, 2008 | 01:50 AM
Corvette Don's Avatar
Corvette Don
Mine stayed down, if you removed your pedal spring it will come back up somewhat.
Old Mar 11, 2008 | 10:25 AM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
If your pedal spring is installed correctly, your pedal should jump right back up, unless your slave or master cylnder is shot.
To Clutch Bleeding
