Well, I did a compression test last night and the numbers were okay-ish with 170-195 after 6 cycles in each, but #7 lagged behind at 90. Crap, it was 90 every time. After 1 cycle they were all 110-130, though #3 was 150.
I still need to put some oil in #7 and check, as well as do a leakdown, but I'm pretty certain something is wrong, I just need to follow up on it.
Surprisingly the car still pulls strong. I'm hoping I've caught this before things really get torn up. How much work do you think I'm looking at here? I assume all new rings will be in order, but I'm just not sure if that can be done with the engine in the car or not, and if I've likely already sustained more damage.
I'll be doing more tests tonight and post them up.
It may not be the rings at all, it could be a valve leaking from a couple things. Could be bent just a little or even have some carbon on it. I would run the Seafoam through it like people do. I believe most people suck it in through the PCV. Then let the car sit for a bit and fire it up and watch the smoke. If it's carbon this should clean it all up. i would do this before tearing it down..
Reason: spelling
I'll be injecting oil and also doing a leakdown tonight, so we'll certainly have a better diagnosis soon. My gut feeling is rings, but I can't give any quantifiable data yet.
I don't think I've had any wild over-revs since I got new valves with the H/C, but I know things have been hot/lean a few times and I spin it to 7k at the track regularly (real track, not the drag strip).
I see, well if it comes down to having to pull the engine down I think I would start by pulling the head that has the cylinder with low compression. I am working on an LS that's in a Z28 right now and when I tore it down it has very small eye lash morks in a couple of the pistons. He tells me that he hasn't missed a gear and over reved it but ya never know.
Just a thought though valve float can cause the piston to tap the valve also. I hope your lucky and maybe it's just a leaking valve. Good luck .
#7 is also notorious for failures do to the lack of cooling to the cylinder if the Sea foam and leak down doesn't provide any help, I would pull the heads and take a look at 'ol #7. There are plenty of thread on here about this issue, from what I understand the fix is a better water pump.
Not knowing the age or miles of this beast, I hope it is in the head area (valve), as otherwise forget just the rings it's O/H time of the whole motor.
Well, the hot compression test tonight reaffirmed the 90psi in #7. The first cycle would be 50-60psi and then peak at 90psi after 5 cycles of the ignition. Adding oil really didn't do much other than make the first cycle read closer to 70, but it still peaked at 90psi after 5 cycles.
We then did a leakdown on #7 and air blew out the dipstick tube. It looks like the piston or rings is the culprit at this point.
I had the luxury of doing this at a friend's house who has a fried LS6 in his garage. #3,5, and 7 were burnt in increasingly severe fashion. #7 in his had zero compression. My friend noted that he had similar compression numbers in #3, and the cylinder walls seemed to be in pretty good shape. I'm hoping I'll be in the same boat and just toss some new rings and an OEM piston in and get this back on the road. What do you guys think? I plan to just drop the cradle/oil pan and get this done in short order if the cylinder walls are okay. If not we're pulling it and spending serious money.
Honestly There are sets of forged rods/pistons on sale here all the time, might as well spend a extra $$$ and go to a forged set up and be done with it, then you can go forced induction in the future. Plus something had to cause this and not sure of you want to buy a new #7 every 6 months.
I have zero interest in forced induction. Now if I got more safe rpms or quicker revs via new pistons I might be interested, but I'll likely go LS2 once I'm ready to get spendy, so the pistons now would be kinda useless. I might also be interested in anything that bumps reliability over the stock setup.
My tune getting off and life at 7k rpms on the track were the likely culprits.
I like your advice on the better water pump. Any recommendations before I start reading?
Sometimes and in some situations its much easier said than done to pull the whole motor and tear it down. I have access to a lift but don't have my own garage and cherry picker to pull the motor.
Trying to make due with what I've got. I will probably end up putting off the short block plans until I get out of this green machine anyway so I can do it right, as you've said.
Sorry to hear that Brody, I hope it is not hurt to bad, if you need it I have a couple of my old engines at the machine shop waiting to be freshened up that I am not going to be using after I switch to the big dry sump setup.
Hi Dale, thanks for the heads-up. I still need to pull that piston out and see what the issue is. Pulling the head really didn't show me anything. My goal is to get this rolling again for your autox. You'll definitely be hearing from me if it looks ugly.
