C5 wheel offsets.
Old Dec 6, 2001 | 01:10 PM
Springer's LT4's Avatar
Springer's LT4
Cruise-In III Veteran
Default C5 wheel offsets.
Does anyone know the wheel offsets for the various C5 wheels? Mainly looking for 97-98 style wheels and the Y2K style thin 5 spokes.
Thanks!
Jim
Old Dec 6, 2001 | 09:48 PM
EuG's Avatar
EuG
Default Re: C5 wheel offsets. (Springer's 95)
Check out my spreadsheet for some info.
I believe 97-99 and Y2K had same offsets, but not 100% sure
Hope this helps…
Old Dec 6, 2001 | 10:04 PM
C5 Tweaker's Avatar
C5 Tweaker
I believe all non-Z06 are:
Front 6.75"
Rear 7.5"
Old Dec 6, 2001 | 10:36 PM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
Default Re: C5 wheel offsets. (C5 Tweaker)
All I can say is that my GS 17X11 have a 50mm offset for the rear.
Old Dec 6, 2001 | 10:38 PM
Springer's LT4
Default Re: C5 wheel offsets. (wallstAL)
Thanks all.. looking to go with C5 rims on my C4... but I'm wondering if the 18 inch rears would fit all the way around.
Old Dec 6, 2001 | 10:41 PM
ZAP's Avatar
ZAP
YES , THEY WILL FIT , but someone said you need a spacer for the front to fit right. :cheers:
Old Dec 7, 2001 | 10:18 PM
Bob Caffey's Avatar
Bob Caffey
Default Re: C5 wheel offsets. (EuG)
eug THANKS FOR THE SPREAD SHEET INFO ITS VERY HELPFUL. I am thinking about taking my 01 c5 y2k rears and moving them to the front and buying two more y2k style 18 s' with zo6 size & rear offset(i have bpp rear brake scoops and there is little to no clearance inside,apparently they use the z06 air duct) do you know if any forum member has tried this. also will the front caliper work as areplacment on the rear w/o prop valve or anti lock problems?
Old Dec 8, 2001 | 02:56 AM
EuG's Avatar
EuG
Default Re: C5 wheel offsets. (Bob Caffey)
As a matter of fact I do :yesnod:
Yours truly! :D
I’ve got my stock Y2K rears on the front and 10.5x18” Y2K look alikes on the rear. No ducts though…not sure if it makes any difference. I’ve got a bunch of pics on my page if you wanna see. Just follow the link in the sig.
Old Dec 8, 2001 | 04:29 PM
Bob Caffey's Avatar
Bob Caffey
Thanks for the reply, do your rear 18's (given they are wider) have the c5 or z06 offset?
Old Dec 8, 2001 | 07:43 PM
nevrenuf's Avatar
nevrenuf
LS1Edit Guru
Cruise-In I Veteran
Cruise-In II Veteran
Isn't the backspacing the only dimension that really matters here?
Backspacing equals the distance from the surface that contacts the brake rotor to the innermost point on the rim. Mine were about 8.75" on my 18x9.5 factory rims...
What is offset? and wouldnt it figure into the backspacing anyway? It seems to me that the only thing that matters is how far "inside" the rim will go in order to prevent the tire from hitting the inside of the fender liner. Perhaps I'm missing something here..
Old Dec 8, 2001 | 08:29 PM
Bob Caffey's Avatar
Bob Caffey
Default Re: C5 wheel offsets. (nevrenuf)
Yes, you are right, whether you call it backspace or the distance the wheel center is OFFSET from the wheel centerline makes little difference. My question which may have been poorly stated is "are the z06 rear wheels different in any dimension from c5 rear other than the width. thank you for your input. bob
[Modified by Bob Caffey, 4:34 PM 12/8/2001]
Old Dec 8, 2001 | 08:43 PM
MelloYellow's Avatar
MelloYellow
I see a lot of backspacing calcs that look wrong to me.
From the Tire Rack tech section on wheels, Offset is defined as the distance between the edge where the wheel mounts & the CENTERLINE of the wheel. So, a 9.5" rim would have a 4.75" centerline. A 60mm offset is arount 2.5" from centerline. So the backspacing should be 4.75" + 2.5" = 7.25" although the common word on stock Y2K 9.5" backspacing is 7.5", so I don't see where the math is working, or not working for that matter.
What am I or others missing here?
I don't believe you subtract the offset from the wheel width to determine backspacing. Offset is not defined from the outside edge of the wheel, but as the distance to centerline of the wheel where the weight should be most evenly distributed.
Old Dec 8, 2001 | 08:51 PM
EuG's Avatar
EuG
Default Re: C5 wheel offsets. (MelloYellow)
Bob,
They’re exact Z06 rear wheel dimensions. Width, offset, everthing….
Mello
You pretty much got everything right, but you left out the lip width which should be added to determine the backspacing (~0.5”)
[Modified by EuG, 7:52 PM 12/8/2001]
Old Dec 8, 2001 | 09:04 PM
MelloYellow
Hmm. Makes sense, thx!
But I don't get why John/CCW says stock backspacing is 7.5" ? Everyone seems to have a diff number. Bottom line, I think I'm going to have to just pull the damn wheels and measure the backspacing on each before I start cutting my wheels up.
What would centerline be then for a 9.5" ?
[Modified by MelloYellow, 8:06 PM 12/8/2001]
Old Dec 8, 2001 | 09:37 PM
EuG's Avatar
EuG
Perhaps he could answer it. Maybe just rounded up….
Old Dec 9, 2001 | 12:45 AM
Dreamin's Avatar
Dreamin
EuG's spreadsheet is absolutely corrent.
Here is Fikse info... matches EuG exactly: http://www.fikse.com/offsets.html
Old Dec 9, 2001 | 01:15 AM
MelloYellow
Default Re: C5 wheel offsets. (Dreamin)
Yes, I think the Offset info is perfect. It's the backspacing I'm not sure of.
Old Dec 9, 2001 | 05:15 AM
EuG's Avatar
EuG
If you compare what I’ve got that Fikse page both offset and backspacing match perfectly to 0.01” :yesnod:
To C5 wheel offsets.
