Replacing TPS Battery
Old Mar 2, 2008 | 05:29 PM
SSWEET's Avatar
SSWEET
Default Replacing TPS Battery
I know there are people who have experimented with replacing TPS batteries in the 97-00 sensors....What material did you use that was successful in holding the new battery in place once it is soldered to the two leads?
Old Mar 2, 2008 | 07:05 PM
ericdwong's Avatar
ericdwong
I used double sided foam stick tape and just a huge glob of silicone.
Old Mar 2, 2008 | 09:04 PM
Oldvetter's Avatar
Oldvetter
Don't solder battery to leads, too much heat will destroy battery. You can buy batteries with leads already welded to them. Check old posts.
Old Mar 2, 2008 | 09:06 PM
ericdwong's Avatar
ericdwong
Good point!
Old Mar 2, 2008 | 10:04 PM
SSWEET's Avatar
SSWEET
Got it...I ordered batteries from DigiKey...already has the leads attached...just needed ideas on what to use to cover the battery after installation....Thanks for the input...
Old Mar 2, 2008 | 11:23 PM
randy814u's Avatar
randy814u
I did not read the whole thing, but there might be some help in here.
http://forums.corvetteforum.com/show...lace=batteries
To Replacing TPS Battery
