Lingenfelter Fuel Pump
Old Mar 3, 2008 | 08:06 AM
Pineapple1's Avatar
Pineapple1
Default Lingenfelter Fuel Pump
Good morning! Thought I'd save everyone the trouble of reading my old post and just start a new one. Long story short, I need a new fuel pump. I'm looking at the one on Lingenfelter's site
http://www.lingenfelter.com/store/l710650197.html
The site says:
Lingenfelter offers this in-tank fuel pump for high performance applications where the standard pump is not capable of supplying sufficient fuel flow. Designed be a direct replacement for the 1997-2003 Corvette and is perfect for turbocharged or supercharged applications
My car is a completely stock 1999. I recently purchased the car and while I have no upgrades planned right now, it is a possibility in the future. I figured, while I'm replacing the pump, I might as well replace it with a high performance one... However, for the time being, will this fuel pump be suitable to use with a stock motor? Will the additional fuel flow cause any problems with an otherwise stock system?
Thanks, Dan
Old Mar 3, 2008 | 08:13 AM
KublaiKhan's Avatar
KublaiKhan
The additional fuel flow will not hurt a thing as the engine will only take what it needs anyways. You will be fine using this pump in a mostly stock application.
Old Mar 3, 2008 | 08:17 AM
AMRAAM's Avatar
AMRAAM
Your fuel pressure regulator will control that for you. Gald you figured out the problem.
Old Mar 3, 2008 | 08:26 AM
Pineapple1's Avatar
Pineapple1
Great! Thanks to everyone for helping me diagnose this. Any advice on whether or not this is a good brand? It seems to be what everyone else is buying. Also, will I need to purchase anything else such as gaskets?
On the topic of fuel regulators.... My dad owned the car before me. He passed away a little over a year ago. I'm gearing up to replace this fuel pump and figured I might as well replace the filter/regulator while I'm at it since I had no idea if my dad had ever done it. So, I'm cleaning up in the garage yesterday when what should I find? GM10299146, brand new fuel filter! Thanks dad!
Old Mar 3, 2008 | 08:27 AM
BlackZ06's Avatar
BlackZ06
The Lingenfelter, according to the picture, is strictly the pump. The OEM and other "pumps" include the fuel level sensor/sending unit and the hose connections into the tank.
http://partimages2.genpt.com/partimages/46070.jpg
I posted in your other thread some on-line sources for the OEM unit, the above image is from ..
http://www.napaonline.com
They carry a couple of the fuel pumps too ....
Old Mar 3, 2008 | 08:34 AM
KublaiKhan's Avatar
KublaiKhan
Racetronix makes an awesome setup for our cars and it isn't too bad expensive. Around $300 if IIRC. It is a pump that will take care of your needs all the way up to 600 rwhp and more.
Old Mar 3, 2008 | 08:44 AM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
Do you have a link to this info?
From what I know Racetronix only provides a harness for the fuel pump to provide a more stable voltage source for it's operation.
Old Mar 3, 2008 | 08:47 AM
AMRAAM's Avatar
AMRAAM
I'm using the LPE along with the BAP and racetronix harness on my set-up. The reacetronix kit mentioned above uses the same LPE assembly. FP is fairly easy swap, but be sure to read a how-to on it if you haven't already. You have to pull the unit out part way and remove a bracket holding the float assembly on, then remove the float assemby, then remove the unit. I used this link as a guide
http://www.strasser.us/c5/mods/racetronix.pdf
Old Mar 3, 2008 | 08:50 AM
AMRAAM's Avatar
AMRAAM
http://www.racetronix.com/RX-C5-FPK-2.html
Old Mar 3, 2008 | 09:10 AM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
Originally Posted by AMRAAM
Old Mar 3, 2008 | 09:15 AM
AMRAAM's Avatar
AMRAAM
Old Mar 3, 2008 | 09:24 AM
Pineapple1's Avatar
Pineapple1
Ok, thanks for all the replies. I think I'm just going with the LPE. I read through the instructions on their site and it looks like everything will work fine. Should I decide to upgrade later I can always buy the harness seperately.
Old Mar 6, 2008 | 07:36 AM
Pineapple1's Avatar
Pineapple1
Lingenfelter Fuel Pump and new fuel filter installed last night after work..... hardest part was figuring out how to drain the fuel. I found that by removing both the pans protecting the fuel tank, and placing a large bucket underneath, I was able to drain it pretty efficiently by loosening the bolts on the pump housing. After that, it was pretty easy, and the car starts up and runs great! Too bad I was working on it till 4am!
Old Mar 6, 2008 | 08:34 AM
AMRAAM's Avatar
AMRAAM
I just installed my LPE yesterday as well. Not a bad job at all. How did you end up working unitl 4AM?
For future reference, here is how I drained my tank. It worked really well
http://forums.corvetteforum.com/show...0&postcount=17
Old Mar 12, 2008 | 08:36 AM
Pineapple1's Avatar
Pineapple1
Thanks for the reference on draining the tank. I actually saw your post when trying to figure out the best way of doing it. The thing is, my pump was completely dead, so jumping the rely didn't do anything. I also was working with VERY limited tools. Hence the 4am! The fuel pump actually gave out in the parking lot of my workplace. Luckily we have a warehouse, so at least it was warm, but tools... they were scare, as I only had what I brought. BTW, that little clamp ring inside the housing is a PITA without the proper tool. I wound up having to use needle nose pliers.... now I worry every day that it's gonna give out on me! I know it probably won't, I got it pretty damn tight, but it still bothers me!
Quick side note, I changed this thing after work, started around 8 and didn't finish till like 4am.... the next morning, everyone in our office complex was complaining of a "gas" smell!!!! Everyone in my suite knew it was me, but other suites thought there was some sort of a gas leak. The gas company came out, it was a big scene! Oh well....
Old Mar 12, 2008 | 09:43 PM
AMRAAM's Avatar
AMRAAM
I could see that clamp being an issue without the right tools. I used a pair of diagonal cuts and worked perfectly. Sounds like you had a hell of a time with it. glad you got it fixed though.
To Lingenfelter Fuel Pump
