Gear Swap
Old Mar 4, 2008 | 01:34 AM
geterdone's Avatar
geterdone
Default Gear Swap
I am really looking into getting gears for my car, is there a way to install just gears instead of buying a completly new rear diff. If so where to a purchase and how is the install, is there anything else I would need. I just can't afford the cost of a completly new diff when I can just do the gears. Thanks
Old Mar 4, 2008 | 08:40 AM
Mike Mercury's Avatar
Mike Mercury
Originally Posted by 04VaVette
What gear set do you currently have? If you have 2.73 you cant change just the gears, wrong carrier.
while I also would discourage anyone from doing their own internal ring & pinion swap on a C5's transaxle ... many shops (including DTE) can place any gear ratio you want into a 2 series carrier case. Even 4.10's; and they've been doing that for years now.
To the OP; here's some informational pages:
http://mikemercury.home.att.net/342.htm
http://mikemercury.home.att.net/ratio.htm
Old Mar 5, 2008 | 12:09 AM
geterdone's Avatar
geterdone
3.42 gear 03 z06 is what it is.
Old Mar 5, 2008 | 07:45 AM
mrm1149's Avatar
mrm1149
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13
Can of worms trying it yourself...........JMO
Old Mar 5, 2008 | 08:23 AM
Mike Mercury
I think the real discouragement is the amount of labor hours required to do the pumpkin R&R.
Back in the 70's we got so good at swapping R&P gears in our Chevelles, Camaros, and Mustang differentials that we could do it in 30 minutes. If one made a minor mistake.... it was just another half hour to make all the corrections and be on your way.
On the C5 (and any real sports car that utilizes a rear transaxle design) ... it's gonna consume a lot more time to make the initial ratio upgrade; and then an equal amount of time if any corrective repairs need be made by the R&P swapper who made a mistake... ANY MISTAKE... in the exchanging of the internal gears.
If you don't get it right the first time; you'll be kicking yourself in the azz during the re-tear down stage.
Old Mar 5, 2008 | 08:29 AM
mrm1149's Avatar
mrm1149
Hey Mike, us old as dirt guys all did pumpkins with our eyes closed Once every week or so ....
Old Mar 5, 2008 | 03:34 PM
tiojames's Avatar
tiojames
If your diff is in good condition you can get $400-500 for it as auto owners use 3:42s. Get a new diff(you will have new gears, bearings, posi, seals, etc. Changing just the gears is a procedure most home mechanics have neither the tools nor the expertise to do.
Old Mar 5, 2008 | 10:32 PM
geterdone's Avatar
geterdone
That what i figured after talking to some local car buddies.
Old Mar 5, 2008 | 10:41 PM
HPS MASTER TECH's Avatar
HPS MASTER TECH
to change your ring and pinion yourself you would probably spend more in buying the right tools rather than letting a shop do it for you.
To Gear Swap
