2004 Z06 Clutch fluid leak under car...clutch woes?
Have owned my 2004 Z06 now for a few months and after reading everyones advice I bought a large syringe with the intention of changing the clutch fluid at the end of this week. I started the car yesterday and low and behold the clutch pedal sits on the floor and I cannot get any gears. I've tried changing the fluid this morning which was pretty black and after 4 refills of the reservoir it stayed clear, trouble is there was fluid still dripping out of the car. The fluid is coming out about 6 inches behind and to the right of the oil filter, as I suspect, this must be close to the position of the slave cylinder? Since my C5Z is a 2004 model, surely I must have had the later improved slave cylinder so I'm really wondering what could have gone wrong with it. Is it common for the seal to have popped or as I've read in previous threads is it more likely that the bleed screw could be leaking?
I'll jack the car up tomorrow to try and find out exactly where the fluid is coming from.
many thanks for any help
