Issue with Pass side rear axle boot cut, how to replace
Old Mar 4, 2008 | 01:57 PM
Sbrennan's Avatar
Sbrennan
Default Issue with Pass side rear axle boot cut, how to replace
Found some white grease on the inner pass rear wheel and A arm. Dealer says its a cut in the boot, which could be since I did my shocks last summer but I was pretty careful (guess not careful enough, or the dealer is full of it).
So, how hard is it for a backyard mechanic to replace one of these? Any info, including details like part numbers etc is always welcome.
Thanks in advance.
Old Mar 4, 2008 | 03:23 PM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
The dealer found "some" white grease???
The outer boot on my car had a microscopic cut on it and the entire inside of my wheel was covered with black grease.
It sounds to me like someone placed a little bit of the wrong color grease on the inside of your car to pad a bill.
Old Mar 4, 2008 | 05:16 PM
MattB's Avatar
MattB
Check out how much the whole axle half shaft is, its pretty cheap like $75 at NAPA. Either way you have to remove the wheel bearing and its a good size job... Once you have the wheel bearing off the axel half shaft just slides out, no special tools required.
Old Mar 4, 2008 | 05:26 PM
Corvette Don's Avatar
Corvette Don
No you dont have to remove the wheel bearing I just did my CV axle in about 30 mins, its 6 bolts plus the cv axle nut (which is a 33mm by the way), I had to take it back out yesterday cause I got the O'reily reman. ($65) and its causing the diff to leak fluid pass the output shaft seal. They are easy to get out. Remove the upper control arm bolts (2), shock bolts (2), E Brake bolts on the spindle (2) and then the CV axle nut, it will then come right out.
EDIT- you want to get the CV axle nut loose (apply e brake) before removing all the other stuff.
To Issue with Pass side rear axle boot cut, how to replace
