Engine Block Question
Old Mar 4, 2008 | 09:55 PM
ZZ4Vetteguy's Avatar
ZZ4Vetteguy
St. Jude Donor '08-'09
Default Engine Block Question
Ok, I should have asked this with my manifold question, but....
I was told my my tuner that my 01 vert is one of the 01's that used the LS6 block and manifold in it. Is there any way I can tell by looking at it, or any visible identifying marks on the manifold or VIN number that could tell me for sure?
Old Mar 5, 2008 | 09:58 AM
ZZ4Vetteguy
Anyone...anyone
Old Mar 5, 2008 | 10:16 AM
Mike94ZLT1's Avatar
Mike94ZLT1
Yes, look on the passenger side by the water pump and along the front edge of the passenger side cylinder head. On the top edge of the block there will be some bullseye marks about the size of a nickel if you have an LS1 block. If it is an LS6 block there will be no bullseye. All 01+ came with the LS6 manifold standard.
Old Mar 5, 2008 | 12:08 PM
ZZ4Vetteguy
NO BULLSEYE
Ok, thanks.
Old Mar 5, 2008 | 12:25 PM
robvuk's Avatar
robvuk
I understood that all 01' used the LS6 block too. Also that there really is no difference between LS1 and LS6 block. Is this not true?
Old Mar 5, 2008 | 12:29 PM
nj02vette's Avatar
nj02vette
From: Marlton. Increasing performance one speeding ticket at a time! NJ
There are differences between blocks. I believe the LS6 had windows cast in the cylinders for better scavenging, etc.
Net effect though, was that there is no power difference between blocks.
Old Mar 5, 2008 | 02:00 PM
ZZ4Vetteguy
I knew about the 0 power difference, I am just the kinda person who likes to know the little details about the car, and I have been meening to ask for 7 months now.
Old Mar 5, 2008 | 04:26 PM
Mike94ZLT1's Avatar
Mike94ZLT1
Not all 01's got them, and power wise it doesn't matter either way. The LS6 has the cast in windows at the bottom of the cylinder for better bay to bay breathing, a revised valley for the PCV system, and that's basically it.
Old Mar 5, 2008 | 05:26 PM
jovette's Avatar
jovette
Go look up Idahoe Corvette, and then when you get to their website, go the section dealing with the LS1 / LS6, Ruthless pursuit of power.
To Engine Block Question
