HELP with door panel and dash removal!
Old Mar 5, 2008 | 09:31 PM
tknight4305's Avatar
tknight4305
Default HELP with door panel and dash removal!
I need to get the door panel of my 98 C5 but I am scared I am goin to break something....I also need to get the air bag module from behind the radio....
If someone could post a link or somthing of how to take everything off it would be greatly appreciated!
Old Mar 6, 2008 | 12:40 AM
peachtreeplaya's C5's Avatar
peachtreeplaya's C5
Old Mar 6, 2008 | 10:17 AM
Speeed-Racer's Avatar
Speeed-Racer
St. Jude Donor '12-'13-'14-'15-'16-'17
This (through step 7) will get your door panel off...
Door handle removal
This (through step 3) will get you behind the radio, etc...
Radio bezel removal
Speed
Old Mar 6, 2008 | 08:42 PM
ZO6 Lee's Avatar
ZO6 Lee
St. Jude Donor '08-'09-'10
Go slow and you won't have any trouble. Vette Essentials has good instructions.
Old Mar 6, 2008 | 09:12 PM
Dave1998's Avatar
Dave1998
Old Mar 9, 2008 | 10:35 PM
tknight4305
Thanks!
Old Mar 10, 2008 | 07:42 PM
waterzap's Avatar
waterzap
Buy some pins for the panel before you remove it, you will probably break a few. Contact Gene and ask him the part #, or try local GM.
Old Mar 10, 2008 | 07:58 PM
ericdwong's Avatar
ericdwong
The most PITA part is the door handle bezels if you havent done them before. Once you pull the first off you'll how its attached.
Old Mar 10, 2008 | 11:57 PM
rws.1's Avatar
rws.1
The Vette Essentials procedures work....
Old Mar 11, 2008 | 02:13 AM
gmethod's Avatar
gmethod
be careful when pulling on the doors. Make sure to place your hands near the "attach" points before tugging away. The dashboard is pretty easy. Just a lot of work. I'm in the process of reinstalling everything after a full leather upholstery job. Take your time and label everything.
To HELP with door panel and dash removal!
