Multiple misfire
Old Mar 6, 2008 | 07:13 AM
clemsondave's Avatar
clemsondave
Default Multiple misfire
Car is stumbling badly at and above apx 4k rpm. I got a P0300 one time, and a heated bank 1 O2 sensor one time (at idle). We changed plugs and tightened the gap to .30 from the .35 I was running. Replaced all the gaskets on the intake. The misfires seem to be primarily limited to cylinders 6, 7 and 8. Once it misfires, it starts running super rich. There is a slight stumble at idle, barely noticeable. I currently have 100 octane in the tank (which I have run many times before).
Leak down found nothing.
Ideas?
'03 C5Z; P1 blower at 7#; stock fuel system with BAP
Old Mar 6, 2008 | 07:23 AM
lucky131969's Avatar
lucky131969
Ideas?
what is the exact sequence of events here. Have you done any work on the car, or did this just start happening?
Old Mar 6, 2008 | 08:13 AM
clemsondave
I hadn't run it in a couple months. During that time, I pulled off all the engine bay covers/tanks/intake and had them painted. I shortened the BAP cable, but soldered it back to the original dial controller. Installed a DynoJet Wideband.
Our first thought was that I didnt get the intake seated properly. So, I replaced all the gaskets and re-installed.
Old Mar 6, 2008 | 08:20 AM
Casem1's Avatar
Casem1
My P0300 code went away after I cut and reattached spades on the two ground connectors. Just a thought. One is under the intake, the other near the PCV valve.
Old Mar 6, 2008 | 08:49 AM
Richard Nogen's Avatar
Richard Nogen
I just had a similar deal except I got a p0300 once then 2 p0306 witch is a misfire I pulled the pcv system from the valve covers and plugged off the holes on the pcv and the valve covers and pulled the oil dip stick and found a strong vacuum witch indicates a leak in the intake. Might be a cheap easy way for you to test.
Old Mar 6, 2008 | 08:57 AM
clemsondave
I'll check those things, thanks.
Would a bad heated front O2 sensor cause missing at mid/high RPM?
Old Mar 6, 2008 | 03:36 PM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
Yes, the front O2 sensors control the AFR and if that bank is running lean it could act as a misfire.
Old Mar 7, 2008 | 06:21 AM
clemsondave
How about low voltage? Battery going bad, alternator, alternator belt slipping, or a short somewhere? I noticed one time with the hood open, the hood light flickered once or twice when the missing began.
Old Mar 8, 2008 | 04:17 PM
clemsondave
Fixed! The coupler after the MAF must have worked it's way slightly off at the track. It was just a tiny leak, but enough to give me all those problems. Hooked it back up and she revved to 6k smooth as silk!
Every code on the scanner is now perfect.
Thanks for all your suggestions!
To Multiple misfire
