How do you lower a C5 ?
Old Mar 6, 2008 | 03:17 PM
vetteguy8's Avatar
vetteguy8
Default How do you lower a C5 ?
is it hard to lower a C5? i was told u dont need any parts but not sure if this is true, thanks guys.
Old Mar 6, 2008 | 03:44 PM
FKING1's Avatar
FKING1
A search will yield as much info as you need
Old Mar 6, 2008 | 04:02 PM
spicytuna's Avatar
spicytuna
Here are a few links to get you started :
http://www.crossedflags.com/modules....=viewtut&id=12
http://www.frankhunt.com/FRANK/hobbi...5_Lowering.htm
Found them last night when I was searching for the exact same topic.
Old Mar 6, 2008 | 04:09 PM
TrplBlk01's Avatar
TrplBlk01
Are you serious?
Here we go again
Old Mar 6, 2008 | 04:12 PM
drbvac's Avatar
drbvac
I did the same thing - its easier sometimes to ask as the search function is sometimes all over the map - anyway if you keep searching there are a ton of links that show how to do it. Have fun - and read about some of the problems that can occur after you start so you will be prepared
Old Mar 6, 2008 | 05:28 PM
rdroket's Avatar
rdroket
Why would you want to??mine is plenty low as it came from the factory
Old Mar 6, 2008 | 06:15 PM
red88L98convert's Avatar
red88L98convert
just crank the bolts all the way and take the car for a short drive to settle the suspension. once you are done with the drive, measure from the center of each wheel to the wheel well to make sure the car is even from side to side.
you dont need to jack the car up, you can reach everything with the car on the ground.
also, slap on some z06 sway bars and you'll love the 'new' suspension!
took me about half and hour to swap the bars and about ten minutes to crank down the bolts.
Old Mar 6, 2008 | 10:29 PM
AlisonC5's Avatar
AlisonC5
You're just old I bet you think its plenty fast and the stereo is plenty loud too!!!
Andy (just funnin' with ya)
Old Mar 6, 2008 | 10:58 PM
renegad44's Avatar
renegad44
From: This is not a Song, It's an Outburst: Or, The Establishment Blues; Sixto Diaz Rodriguez
Dang...10 minutes on 4 bolts? I should have called you to do mine, the rear was no problem, but hell, I'm still dealing with the front.....
It's not always that easy...FYI...
http://forums.corvetteforum.com/show....php?t=1958452
Old Mar 7, 2008 | 04:11 PM
vetteguy8's Avatar
vetteguy8
thanks guy for the links and info.....
Old Mar 30, 2008 | 12:22 PM
Kamil D.'s Avatar
Kamil D.
Old Mar 30, 2008 | 07:02 PM
Zeeohrix's Avatar
Zeeohrix
Yes thank you for the links!@!!!!!!! Im lowering my Z06.. its that easy!!! , so why did i order a set of lowering bolts and bushing? if all i had to do is crank some screws??????
Old Mar 30, 2008 | 07:05 PM
doje's Avatar
doje
St. Jude 15 Year Donor
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20
The kit will allow you to go even lower. There is a big limit to how low you can go on stock bolts. The kit will let you SLAM it.
Old Mar 30, 2008 | 07:06 PM
Zeeohrix's Avatar
Zeeohrix
Awesome, i knew they sold them for a reason... thnx
To How do you lower a C5 ?
