which heads and cam to get...
Old Dec 7, 2001 | 01:24 AM
VERTVETTE's Avatar
VERTVETTE
Default which heads and cam to get...
I want to be around 400/425hp at the rear, without braking s@#t thanks for any advice on a proper setup. :confused:
Old Dec 7, 2001 | 01:32 AM
odie's Avatar
odie
Default Re: which heads and cam to get... (VERTVETTE)
Check out Norris Motorsports (there is a link to his web site
on the forum), he is in the Orlando area.
I'm getting a heads & cam ,headers and x-pipe done in
the next few weeks. :cheers:
Old Dec 7, 2001 | 01:34 AM
Plastic Pig's Avatar
Plastic Pig
Live Free or Die
From: One thing is for sure this kind of discourse and BS would not be tolerated on the NCRS forum. Ohio
Call Cartek and ask them for Mark's package :D. It ran 11.19, and is great for a daily driver.
I've had excellent results from them.
Old Dec 7, 2001 | 03:52 AM
DARTH VETTER's Avatar
DARTH VETTER
You've got mail.
Old Dec 7, 2001 | 07:50 AM
CoolSSBoy's Avatar
CoolSSBoy
VERTVETTE,
Like odie mentioned, Norris Motorsports for sure. Well worth the while since you are near for sure. 407-656-2600.
AJ
Old Dec 7, 2001 | 10:07 AM
C5Longhorn's Avatar
C5Longhorn
Default Re: which heads and cam to get... (CoolSSBoy)
I'd go with a tuner thats close to you in case you need follow up service. It sounds like Norris Motorsports would fit this bill. Good luck.
Old Dec 7, 2001 | 10:49 AM
DUKE's Avatar
DUKE
Default Re: which heads and cam to get... (rschiltz)
Mike Norris is your man. See sig.
Old Dec 7, 2001 | 01:18 PM
Chris@SD's Avatar
Chris@SD
What are you looking for? Emissions? Do you want a little rumpity-rump in the idle? Are you going to drag race, road race, or daily drive? Before we can get into the specifics of what you are going to need and can suggest anything, we need to know you wishes. With a 6-speed, 400 is extremely easy! With a good sized cam, I would be looking for 420+RWHP with LT headers, intake, and pulleys and you will have a very strong curve (lots of power under the curve, not just at peak).
Good Luck,
To which heads and cam to get...
