Anyone use this filter?
Old Mar 7, 2008 | 10:14 AM
tramminc's Avatar
tramminc
Default Anyone use this filter?
picture may not exactly match actual product
+ view larger image
By: TRUFILTER
Aluminum lifetime reusable, washable oil filter
( Write Review )
Description: LIFETIME FILTER SYSTEMS
ECONOMICAL BENEFITS
Good for the life of your motor. Lifetime Warranty.
Superior filtration means less wear on engine or fuel systems, providing extended life of equipment.
Eliminate filter inventory.
Eliminate cost of filter disposal.
Extended oil change intervals from 3000 miles to 7000 miles.
Saves money and time and the environment.
PERFOMANCE BENEFITS
MOST EFFICENT FILTRATION- Laboratory tested and competition proven to be over 90% more efficient in removing 35 micron and smaller particles. (Most harmful to engines) than paper filters.
LARGEST FILTERING AREA- deep pleated, duplex woven, 45 micron, T304 stainless steel filter media has the largest amount of filter area available and provides for “one-pass” ABSOLUTE filtering. Cleaner oil equals longer engine life, longer oil life, better fuel economy and fewer emissions.
MAXIMUM FLOW VOLUME- Our quad flow technology doubles the filtered oil flow allowing you motor to run more efficient.
REUSEABLE & CLEANABLE-reusable hundreds of times. Cleaning can be done with soap and water or in a solvent parts washer.
EASY INSTALLATION-no special tools needed. Simple spin-on replacement. Best fit and NO LEAKS! Convenient finger grips for a TRU grip.
REMOVABLE INSPECTION CANISTER- easy removal to allow inspection & cleaning-anytime.
SUPERIOR QUALITY & WORKMANSHIP- 6061 T6 billet aluminum housing is designed, engineered and manufactured to last the life time of your truck, car or equipment.
O RINGS- Viton ®, lifetime seals, the ultimate in durable sealing ability.
FULL FLOW BYPASS- stainless steel spring and ball incorporated in a unique design for emergency oil flow requirements.
ENVIROMENTAL BENEFITS:
Eliminate the used oil and filter from the waste stream
Lifetime filter systems, through superior filtration, can help extend oil drain intervals, thereby reducing the used oil waste stream
Helps protect our environment
» see other products by TruFilter
Sorry can't load picture.
Old Mar 7, 2008 | 10:32 AM
warpster's Avatar
warpster
How about a link? You don't really give enough info to determine what filter you are refering to....
Old Mar 7, 2008 | 11:49 AM
tramminc's Avatar
tramminc
http://www.trufilter.com/
Old Mar 7, 2008 | 12:45 PM
BUGZ's Avatar
BUGZ
Sounds very interesting. $150 Bucks....what is the average cost of the BEST throw away? Delco Gold? How does the filtering properties of this one compare to the best throw away?
I have not had the pleasure of changing my oil...still have 45% on the DIC
Old Mar 7, 2008 | 12:58 PM
MagRedConv's Avatar
MagRedConv
I use K&N. It has an anti drain back valve, no dry starts also has an eyelet for safety wire; $7.50
Old Mar 7, 2008 | 01:12 PM
BUGZ's Avatar
BUGZ
I heard K&N pretty is good. I believe I have a K&N on mine.
Rounding to $8 bucks a copy...it would take about 19 oil changes or 57,000 miles (if you change oil every 3K) to pay for the new filter.
Not sure if it is worth futzing with. Maybe for the tracked car, but not for the garage queen? I'll save my $150 for CCW Classics
Old Mar 7, 2008 | 03:23 PM
nextime's Avatar
nextime
Every vehicle is designed for a certain operating pressure of the drainback valve, this is why I only use OEM filters. Anything more or less can contribute to engine wear.
Ford I use Motorcraft and GM I use AC only.
Old Mar 7, 2008 | 06:32 PM
tramminc's Avatar
tramminc
it has a big magnet in it.
Old Mar 7, 2008 | 06:39 PM
hotwheels57's Avatar
hotwheels57
Buy a AC DELCO, WIX, K&N or MOBIL 1 filter and add a FILTERMAG (from SUMMIT RACING) to the outside vertical surface of the metal filter. It's a lot cheaper.
BTW, I've used the after market reusable filters on sbc and sbf motors for years, but the prices have gotten just to crazy to justify them anymore.
Old Mar 7, 2008 | 10:50 PM
jgump's Avatar
jgump
What size filtermag?
Old Mar 7, 2008 | 10:54 PM
thetaxman's Avatar
thetaxman
TFSD18
I'll pass but the concept if it works is good.
I just cut my filters open to look at what's in the filter
To Anyone use this filter?
