Which is better, lean or rich? (MAFT question)
Old Dec 7, 2001 | 12:31 PM
MattG's Avatar
MattG
Cruise-In I, II, III, IV & V Veteran
CI-I & II Auto-X Champ
Default Re: Which is better, lean or rich? (dsk888)
Anywhere around +5 on the LTFTs is good in my opinion. I have heard you are more apt to pull a degree or two more timing when your LTFTs are slightly in the positive. I would leave it where you are at.
Old Dec 7, 2001 | 01:50 PM
allanlaw's Avatar
allanlaw
Dan, were the KR values at WOT or not? Looks to me like you are good for non-WOT. I'm a rookie at this, but if I were you, I might try one click rich for WOT setting on the MAFT.
Old Dec 7, 2001 | 02:53 PM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
Same principle, look at your bank account. Would you rather be rich or lean??
Old Dec 7, 2001 | 03:10 PM
Austrian Vette's Avatar
Austrian Vette
Default Re: Which is better, lean or rich? (wallstAL)
:D :smash: :D
Old Dec 7, 2001 | 05:51 PM
allanlaw's Avatar
allanlaw
Allan, I'm getting some KR in both base & WOT, actually more so in the base. I just went back and checked, most of the KR occur at low rpm (900-1200), but there are a couple at ~2200 rpm. Also, the KR happened between fuel cell trims 6-13.
I went ahead and turned the WOT setting 1 click to the right to 2% rich, and left the base at 30% lean. Hope this will cure the KR problem. :seeya
OK, if you are getting most of your KR at lower rpm, I think I would back off the lean on the base by a click, and leave the WOT at 0 for the moment. See how that changes things. If that eliminates the KR at lower RPM, but there is still some at WOT, then try one click rich (2%) for WOT. I think you first have to deal with the KR at low RPM - I have never seen ANY KR in my car except at WOT. Damn, sounds like you're getting really close.
Old Dec 7, 2001 | 05:58 PM
kewlbrz's Avatar
kewlbrz
Cruise-In II Veteran
Cruise-In III Veteran
dsk, I will email you my work address so you can communicate better with me.
Id stay at the setting that keeps you at that +3 or so on your trims.
Its better to simply monitor WOT by looking at Throttle position. I dont try to average via a fuel cell for WOT. I just look it over to get the jist via looking at the Throttle position. When you get my email address, send me your latest trace and maft settings.
Old Dec 7, 2001 | 06:10 PM
allanlaw's Avatar
allanlaw
Default Re: Which is better, lean or rich? (kewlbrz)
Shawn, would you ignore his KR at low rpm, and if not, what would you suggest?
Old Dec 7, 2001 | 06:19 PM
kewlbrz's Avatar
kewlbrz
Default Re: Which is better, lean or rich? (allanlaw)
I was under the impression he got KR when he was at 30% lean setting, but he backed down to 25%. Mabey I misread. No I wouldnt ignore KR at non WOT.
dsk, are you lugging the engine when you getting KR, what gear and vehicle speed, and rpm? What Octane fuel?
Old Dec 7, 2001 | 06:40 PM
allanlaw's Avatar
allanlaw
He was getting KR at 30% lean, and I suggested he go to 25% to see what would happen, leaving the WOT at 0. Looks to me like you and I are telling him the same thing, to try 25% BASE. Of course, it could be he was just lugging the engine a tad, which is always a sure way to get some knock if there is any to be had.
To Which is better, lean or rich? (MAFT question)
