LSA question
Old Mar 7, 2008 | 01:54 PM
OhioC5's Avatar
OhioC5
Default LSA question
Can someone explain a LSA of 113 +2? Does it mean there was 2 degrees of advance ground in the cam? If so, what is the advantage. Cam in question is 228/232 on a 113+2 lsa 588/584
I searched and could only come up with 113 LSA before people call me lazy.
Old Mar 7, 2008 | 02:02 PM
DPG's Avatar
DPG
St. Jude Donor '06
you are right, the advance is just built into the cam, i believe its basically a 115 lsa cam.
Old Mar 7, 2008 | 02:13 PM
OhioC5's Avatar
OhioC5
Thanks, wonder why they dont just call it 115 LSA?
Old Mar 7, 2008 | 02:16 PM
BlueRag's Avatar
BlueRag
What an LSA of 113 means is the cam has a lobe seperation angle of 113' between the intake and exhaust lobe centerlines. the +2 means that the cam was ground with 2' of advance.....making the intake centerline (ICL) 111' past TDC when you install it "dot to dot". The seperation between the intake and exhaust is still 113'. The +2 advance enhances the low end power slightly.
Old Mar 7, 2008 | 02:33 PM
DPG's Avatar
DPG
St. Jude Donor '06
well stated, thanks
Old Mar 7, 2008 | 05:22 PM
happa's Avatar
happa
I learn something new everyday on here!
To LSA question
