Exhaust valve question
Old Dec 7, 2001 | 09:25 AM
68 Magnum's Avatar
68 Magnum
Default Exhaust valve question
I've been told that the new exhaust valves on some 'vettes are filled with sodium and or potassium. Is this true?
I assume this aids in cooling as the heat capacity of these elements is extremely high. I also assume this transfers heat from the hot face of the valve to the relatively keeper end of the valve stem.
What form is the sodium/potassium in when cold? When Hot?
What is the volume of the hollow stem and how many grams of sodium/potassium?
Although I have a low tech 68 vette, I am a high tech guy with a background in chemistry and materials engineering who is always interested in the latest technology.
Old Dec 7, 2001 | 09:49 AM
Godspeed's Avatar
Godspeed
Senior Member
Cruise-In III Veteran
Cruise-In IV Veteran
Default Re: Exhaust valve question (68 Magnum)
Yes the 2002 LS6 motor uses sodium filled valves, but I thought it was just for weight reduction, but heat transfer may make sense too.
