B2282 and B2284 codes?
Old Mar 8, 2008 | 08:23 AM
mxw1's Avatar
mxw1
Default B2282 and B2284 codes?
I keep getting these codes and have noticed these codes on every C-5 I've checked.
I don't have any problems with my car, but the code is there.
Anybody Know what the explanation for these codes is?
Thanks,
Mike
Old Mar 8, 2008 | 09:34 AM
Plasticfan's Avatar
Plasticfan
Both of these codes refer to the power supply coming to the Left Hand Door Control Module being too high or too low. You might want to check and clean the connectors in the rubber bellows near the door hinges. I've never seen this code on mine so maybe other members can be more helpful.
Old Mar 8, 2008 | 10:11 AM
trussme's Avatar
trussme
Thanks,
Mike
Mike... here are the 2 Code Definitions that apply:
DTC B2282 Battery #1 Circuit
DTC B2284 Battery #2 Circuit
...if these are -H codes (History) disconnecting (negative) battery cable will remove them & historical codes usually do not return.
To B2282 and B2284 codes?
