Jack IT UP!
Old Mar 8, 2008 | 11:39 AM
98PewterCoupe's Avatar
98PewterCoupe
2nd Gear
Default Jack IT UP!
I am new here, but not a new owner. Since this is my first car with a removable roof, I was wondering if anyone could set me straight on lifting the car both on hydraulic lifts and floor jacks. I always heard you should pop open a door to prevent the frame from bending/contorting, but never understood this. Also, can you jack up only one wheel at a time (just enough to remove the wheel) or will this damage the car?
Thanks and look forward to many more posts and threads!
Old Mar 8, 2008 | 12:06 PM
nj02vette's Avatar
nj02vette
From: Marlton. Increasing performance one speeding ticket at a time! NJ
You don't need to open a door or do anything super-special to jack the C5 vette.
The car was designed from the beginning as a convertible, so it doesn't suffer from any of the issues associated with other "we're just going to cut the roof off to make a convertible" cars. The hydro-formed rails helped make this the stiffest frame every made at the time.
However, there are several things to note. The bottom of the car is actually made from a sandwich of fiberglass and balsa wood. Putting a jack under this will crack it. You should only lift it at the designated jacking points. You'll see these under the car right by each wheel. Some sell jacking pucks, or you can just use a hockey puck to protect the area as you jack. Even better place to jack is the front and rear cross-members. Slide a jack under the cross-member and lift the whole front or rear of the car.
The only issue with jacking is you need a low profile jack, or you have to drive the car up boards to get it high enough to get a standard jack under it.
Welcome to C5
Old Mar 8, 2008 | 01:29 PM
Russ K's Avatar
Russ K
This is the safe & right way to lift a Corvette. I use the floor jack insert if I just need to lift up the car to remove a wheel. Using a hockey puck can/will slip out of place causing damage to the rocker panel, or personal injury. The lift pads are used when I raise the car on a hoist.
Jack insert - http://www.mamotorworks.com/corvette-2-66-174.html
Lift pads - http://www.mamotorworks.com/corvette-2-66-3064.html
Russ Kemp
Old Mar 8, 2008 | 10:27 PM
98PewterCoupe
2nd Gear
Thanks for all the info - this definitely makes me feel a lot better, knowing I am not destroying anything! I already have the jack inserts so I will give it a try!
Happy Driving!
Old Mar 10, 2008 | 10:15 AM
jovette's Avatar
jovette
Read your owner's manual. It will tell / show you how / where to lift the car.
Old Mar 10, 2008 | 10:33 AM
Got uid0's Avatar
Got uid0
St. Jude Donor '17
bmw jackpucks are cheaper
http://www.bavauto.com/fland.asp?par...1+71+1+960+752
To Jack IT UP!
