Koni FSD install question
Old Mar 8, 2008 | 04:23 PM
ericdwong's Avatar
ericdwong
Default Koni FSD install question
I'm in the process of putting in Koni FSD's- but the package does not come with any sort of "boot" for the shock ... did you install them without the boot? Or- did you use the boot off your original shocks?
Old Mar 8, 2008 | 06:58 PM
BanditDude's Avatar
BanditDude
I replaced F45's, and re-used their plastic sleeves. I'm not familiar w/ the other shocks, so I can't help you there. Maybe someone else will chime in.
Old Mar 8, 2008 | 08:00 PM
Cobra4B's Avatar
Cobra4B
CI 3-5-6-7-8 Veteran
You have to hone out the oem ones and reuse them.
Old Mar 8, 2008 | 09:11 PM
rustyguns's Avatar
rustyguns
or leave them open and don't drive in the rain or on a dirty road
Old Mar 8, 2008 | 10:20 PM
jam999999's Avatar
jam999999
I had them installed on my 99. They come with a 0.1 inch thick white plastic discs that partly cover the top of the shock. I called Koni directly and they said that is all that is needed. No boots. You can put on an old set of boots, but they are not needed. When I removed the Koni's from my car, decided to go with a coilover kit, there was very little dust or debris on the disks.
Good luck with the install,
john
Old Mar 9, 2008 | 01:28 PM
ericdwong's Avatar
ericdwong
john
OK that's great to know. I'll just use them without it then.
To Koni FSD install question
