Does this need attention?
Old Mar 8, 2008 | 05:16 PM
stevedun's Avatar
stevedun
Cruise-In 8-9-10-12 Veteran
Default Does this need attention?
OK guys and gals, I just changed my brakes and rotors all the way around, hoping to rid myself of a braking vibration. I only got it on braking. No vibration at high speed or when down shifting to slow down. So I figure the new rotors will solve this. Both back rotors had a small line that looked like a crack across each rotor. Anyway, while I had it apart, I was inspecting all the bushings and linkage and noticed two different things I want to make sure are normal and will not be a problem. The first two pics is a connector type rod from the rear sway bar. Rubber bushing looks to be worn or broke down. Second two pics looks like a nut should be here (front fiberglass leaf spring) but both sides are like this, so this must be normal? Thanks for any insight!
Old Mar 8, 2008 | 05:28 PM
AlisonC5's Avatar
AlisonC5
Front looks normal. you can screw that speed nut down if you want, its no biggy.
the sway bar end links should be replaced. They look to be plastic, you can replace them with aluminum ones. IMO. BUT, I would not think that would be the cause of braking vibration. I'm no expert.
Andy
Old Mar 8, 2008 | 06:07 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Personally speaking, if it was my car, those would get replaced. I'm not sure if it would make a lot of difference though.
Old Mar 8, 2008 | 07:34 PM
stevedun's Avatar
stevedun
Thanks guys!! That was my thinking also. Probably not a handling problem, but I would feel better. Thanks again!!! Wonder what the part number would be? I will check with Gene.
Old Mar 8, 2008 | 08:27 PM
noahdr's Avatar
noahdr
most vibrations from braking are caused by bad shocks. everyone assumes their rotors are warped but 90%of the time its the shocks not doing their job.
Old Mar 8, 2008 | 08:47 PM
Russ K's Avatar
Russ K
Bad shocks won't cause a vibration only when braking. Replace or turn the rotors.
Russ Kemp
Old Mar 8, 2008 | 09:12 PM
ALLEGRO's Avatar
ALLEGRO
It is not your vibration problem, but I would replace those endlinks.
Old Mar 9, 2008 | 01:45 AM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Use metal end links and your handling will increase dramatically. The plastic ones bend.
Old Mar 9, 2008 | 04:56 AM
DefenderC5's Avatar
DefenderC5
Your pictures look normal and my plastic endlinks looked like that too when I replaced them. Gene will have the aluminum ones.
Did replacing your rotors fix your braking issue? I had the same problem. The braking vibration is pad material buildup on the rotor. A couple of 80-20mph hard stops clear it up, but it comes back in a few hundred miles. I switched to a slotted rotor and the issue never came back.
Old Mar 9, 2008 | 06:15 PM
stevedun's Avatar
stevedun
Well, it appears the vibration is gone. I put on PowerSlot slotted rotors and Hawk HPS brake pads. I put 120 miles on since the change lightly braking the first 70 miles to get the cadmium finish off per instructions. I did get a thump thump thump when leaving the club today, but could not recreate it. Hoping it was just the road, but felt like right rear. Everything was torqued to factory specs, so nothing is loose. I do have some squeal on stopping. We will see if things improve over time and break-in. I tried the hard braking stops with the old pads and nothing helped. It just vibrated harder!!!
Old Mar 10, 2008 | 12:22 PM
DefenderC5's Avatar
DefenderC5
We were supposed to lightly break those off? I bed my rotors/pads on them. The cadmium was gone in a 15 min drive. Oh well, they've been performing well.
To Does this need attention?
