Radiator coolant change 2003 vette
Old Mar 8, 2008 | 06:20 PM
rried2tall's Avatar
rried2tall
Default Radiator coolant change 2003 vette
I want to change my coolant because my owner manual recommends changing at 45000 miles, I don't have a shop manual yet and don't want to mess up. Are there any tricks such as air bleeds on the engine block or can the radiator be drained and refilled with out any problems?
Thanks Ron
Old Mar 8, 2008 | 06:48 PM
DALE C's Avatar
DALE C
No bleeds on the C5 they usually fill easy without any air pocket problems
Old Mar 8, 2008 | 09:15 PM
ALLEGRO's Avatar
ALLEGRO
The LSx motors are usually easy to change the coolant in. The LT1 was a real bugger with its "Reverse Flow System."
Old Mar 9, 2008 | 11:17 AM
Oldvetter's Avatar
Oldvetter
Don't know what owner's manual you have, normal service is 5 years or 150,000 miles ! Yours is due on time.
To bleed air, fill tank to cold fill level and rev motor alternately to 3,000 rpm until temperature gets to 210 F. Do this 3 times, ending with coolant 1/2 inch over cold fill line.
To Radiator coolant change 2003 vette
