Not your typical headlight problem
Old Mar 10, 2008 | 12:58 AM
N0TDADYS_98's Avatar
N0TDADYS_98
Default Not your typical headlight problem
problem resolved with new headlight
Old Mar 10, 2008 | 02:29 AM
Bluefire's Avatar
Bluefire
Below the painted top are four white nuts standing off of studs. The top actually sits on these four nuts. Those are the levelers for the painted top. Turning them will adjust the height of the individual corners. HTH.
Old Mar 10, 2008 | 01:39 PM
vermjpv's Avatar
vermjpv
Now a CTS-V Owner
CI 5-6-7 & 9 Veteran
St. Jude Donor '05-'06-'07-'08
I'd guess that You bent the metal brackets of the headlight assembly. Can You check against the other light??
Old Mar 10, 2008 | 01:56 PM
timemender's Avatar
timemender
Post those photos - they may help. The discription of the impact in your second post helps also. Even a 5-MPH crash is a LOT of force. Bracket damage seems reasonable.
Old Mar 10, 2008 | 02:07 PM
N0TDADYS_98
new headlight installed, problem resolved.
To Not your typical headlight problem
