Just wanted to know what tools were needed to change my spark plugs.......What I mean is what swivels are needed to get old number 7 out.....Could you please post pics.....Thanks
no swivels needed... just a 5/8" deep drive socket(aka spark plug socket) and ratchet. we dont have f bodies, where the back part of the engine is under the cowl. its much easier to change the plugs on these cars. it should only take you about 15-20 minutes to do all 8 plugs. the back ones(#8 and #7) are harder to remove, only because you have to turn the ratchet at such a slow speed. just takes time though. very easy to do.
I don't have pics, but I got all my spark plugs out with 5/8 spark plug socket, short extension, and the 3/8 swivel.
My problem was getting the spark plug wires off. I bought a boot plier from Auto Zone that worked on the easy ones. Twist a half turn or so and it comes off. Some did not twist off so easy. I ended up replacing the spark plug wires cause I broke one. Use some high temp grease on the plug boot, it came with my spark plug wires.
edit: this is with longtubes...
do you have midget hands or something No offense if you do, but I had a hell of a time getting back there.
I just did mine and had to use a spark plug socket and a large metric box end wrench to get #7. I didn't have any issues with wires, just only pull on the boot and it's not so bad. Mine had never been done (98' 115K) and were not hard. If i had a swivel socket and short extension it wouldv'e gone alot faster
~B~
