Rotor Question?
Old Mar 11, 2008 | 08:33 AM
Itallian33's Avatar
Itallian33
Default Rotor Question?
Has anyone put the drilled and slotted rotors off the C6 on the C5? Are they the same size as our stock?
Old Mar 11, 2008 | 08:52 AM
byte_me's Avatar
byte_me
the drilled rotors from a C6 are the Z51 rotors- they are larger then the stock C5 rotors (both front and back) and require a caliper offset bracket to install them on your C5. If you are not going with at least a Z06 17" rim (told they fit) or an 18" front rim- these will not fit your stock 17" C5 front rim. The C6 Z06 brake system is a whole other story- $1600 +\- and you must run larger rims in the front for them to work.
A lot of people are going this C6 Z51 route for a "Big Brake" upgrade to the C5...+\- $500 for the parts required at gmpartshouse and Gene Culley.
4 rotors- 4 caliper brackets and you reuse your C5 calipers as they are the same as the C6 units.
I am considering this myself.
Old Mar 11, 2008 | 09:50 AM
Itallian33's Avatar
Itallian33
Thanks for the info. Sounds like they will not fit my stock size rims.
To Rotor Question?
