C6 Knob on C5 shifter
Old Mar 11, 2008 | 10:14 PM
MikeeVet's Avatar
MikeeVet
Default C6 **** on C5 shifter
Would the C6 **** fit on a C5 Kirbin Short throw shifter ,
Old Mar 11, 2008 | 11:35 PM
chevy406's Avatar
chevy406
The C6 **** slides onto the shifter, and is held on with a set screw. The C6 shift lever has a drilled & tapped hole ~ 1½" down from the top for this set screw. The C5 shifter is threaded on the top, and the **** screws onto the shaft. It is locked into position with a wedge. The C6 **** has been tapped to work on the C5 shifter. I don't know if it is just as easy as running a tap into it or if you need to add a threaded insert.
Old Mar 11, 2008 | 11:41 PM
NemesisC5's Avatar
NemesisC5
I have a custom designed C6 **** on my C5 Kirban shifter...It just threads on with perfect fit, you can buy them from GS Creations
Old Mar 12, 2008 | 05:35 AM
MikeeVet's Avatar
MikeeVet
Default C5 ****
Thanks for Info Scotty just order one
Old Mar 12, 2008 | 07:20 PM
NemesisC5's Avatar
NemesisC5
You're welcome Bro you will enjoy the new C6 ****...it is worlds better than factory C5 "clunker"
To C6 Knob on C5 shifter
