Clutch install with TPIS headers
Mar 13, 2008 | 02:27 PM
Getting ready to replace clutch, will my TPIS headers have to be removed? Thanks
Mar 13, 2008 | 03:28 PM
I have Kooks, not TPIS, but I didn't have to remove them completely. I did have to loosen them though. I ended up taking out all the header bolts but one. I left it in to hold the Headers out of the way.
Mar 13, 2008 | 03:57 PM
i have TPIS and i did nto remove them, but had to unbolt them. i left them in place and worked around them
Mar 13, 2008 | 04:02 PM
Quote:
Originally Posted by
02gt350
So you are saying you unbolted them from the heads? Looks like I need to get some exhaust gaskets. Any suggestion on gaskets?.
Mar 14, 2008 | 02:01 AM
95formula
OEM MLS gaskets
...or just reuse the stockers
Mar 14, 2008 | 06:26 AM
95formula
yes. Just unbolt them from the heads. Youshould be able to move them around enough underneath to do what you need to do
Mar 14, 2008 | 11:50 AM
95formula
yes, from the heads, and just let them hang. if you have these headers, you should have 2000 camaro gaskets that are round, not oval
Mar 14, 2008 | 04:42 PM
Mar 15, 2008 | 07:46 PM
Check your torque tube bushigs while you are at it. Change out the hydraulics and get a remote bleeder too.
Good Luck
Mar 16, 2008 | 09:56 PM
Brad@RevXtremeAutoSports
Good Luck
Will check the bushings once apart. I plan on replacing the slave and adding a remote bleeder. Is there any reason to replace the master?
