Voltage variations
Old Mar 13, 2008 | 10:43 PM
Padrino's Avatar
Padrino
Default Voltage variations
Got a "service vehicle soon" light tonight on the way home. Hit the guages button. When it scrolled to the voltage it was going between 14.1-14.2-14.3 back and forth and never settled down. I had my stereo on (with amps), no A/C nor the lights as it was still too early. What am I facing???????? Any clues or experience on this type of electrical voltage swing????
Padrino
Old Mar 14, 2008 | 02:02 AM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
Start by checking alternator connections, then battery connections, ground connections. Check all for cleanliness and tightness.
Old Mar 14, 2008 | 07:42 AM
Padrino's Avatar
Padrino
Thanks BBZ06. My weekend project.
Padrino
Old Mar 14, 2008 | 08:31 AM
lucky131969's Avatar
lucky131969
Padrino
I would hardly call a .2 change in voltage a swing.
Old Mar 14, 2008 | 11:11 AM
JH's Avatar
JH
That is pretty minimal insofar as a variation, likely explained by differing demand load on fuel pump, etc.
Old Mar 14, 2008 | 11:13 PM
vetteguy02's Avatar
vetteguy02
As noted above .2 variations would be within normal operating limits for a car’s electrical system. Service engine soon message, normally refers to smog equipment malfunction. Make sure your gas cap is on tight and also look at anything else smog related.
To Voltage variations
