Clutch pedal stop
Old Mar 16, 2008 | 11:22 AM
Corvette-Chris's Avatar
Corvette-Chris
St. Jude Donor '08
Default Clutch pedal stop
Does anyone use a clutch pedal stop? How do you like it if so?
http://carolinaclutch.com/ShowItem/110183.aspx
Old Mar 30, 2008 | 03:49 PM
John Shiels's Avatar
John Shiels
From: Buy USA products! Check the label! Employ Americans
bought it and it doesn't even fit over the pedal you also need to cut off the stock pedals neutral safety switch tab on the pedal which sucks!
Old Mar 30, 2008 | 04:16 PM
miami993c297's Avatar
miami993c297
I was using the one from carolina with the Textralia and it was perfect...
I HAVE IT TO SELL as I am using another brand of clutch were the pedal stop doesn't work.
Christian
Old Mar 30, 2008 | 07:13 PM
John Shiels
what will you do now that you cut the tab off pedal? Weld one back?
Old Mar 30, 2008 | 07:54 PM
miami993c297
The Clutch Pedal Stop I bought used from a forum member here is a direct bolt on completely adjustable and a very nice of machined piece:
It was useful with my ex Textralia Exo-Skel and I don't use it anymore with my new RPS Twin Carbon.
I didn't need to weld anything to make my pedal work without it...
Christian
Old Mar 30, 2008 | 08:51 PM
John Shiels
http://forums.corvetteforum.com/show...tch+pedal+stop
Old Mar 31, 2008 | 09:58 AM
HP_Addict's Avatar
HP_Addict
I have one that I got from ECS. It looks like the one pictured. It works well and really helps with clutch engagement, especially at the track.
Old Mar 31, 2008 | 03:57 PM
miami993c297
Hi John Shiels,
That is the one I have and I will sell...I bought this modified Clutch pedal Stop from chuckster when he went to a brand that didn't require it anymore....same case for me today.
If I was still using a Textralia Exo-Skel I would have it mounted for sure, it saves to overextend the finger springs.
Christian
To Clutch pedal stop
