Speedbleeder on the clutch?
Old Dec 8, 2001 | 11:09 PM
ZAP's Avatar
ZAP
Default Speedbleeder on the clutch?
Anybody try one on the slave cylinder? :cheers:
Old Dec 9, 2001 | 04:58 PM
ZAP's Avatar
ZAP
Default Re: Speedbleeder on the clutch? (ZAP)
anybody?
Old Dec 9, 2001 | 05:04 PM
C5Cemo's Avatar
C5Cemo
There are no provisions for them on the clutch hydraulic system that I've seen.
Check out these pics for reference:
:seeya
Old Dec 9, 2001 | 06:24 PM
Godspeed's Avatar
Godspeed
Senior Member
Cruise-In III Veteran
Cruise-In IV Veteran
The fastest way to do it with it still on the car would be a vacuum bleeder on the reservoir.
Old Dec 9, 2001 | 10:54 PM
ZAP's Avatar
ZAP
Default Re: Speedbleeder on the clutch? (Godspeed)
how do you bleed the throwout bearing? this looks similar to a racing throwout bearing. we have a bleeder on ours :cheers:
Old Dec 9, 2001 | 11:07 PM
vetteshop's Avatar
0vetteshop
Former Vendor
St. Jude Donor '13
The hydrolic throw-out bearing in the photo (some call it a slave,the C-5 does not have one) can be bleed from the fitting seen in the photo.The fitting exits the bell housing,and you have to remove the H pipe to access it...
Old Dec 10, 2001 | 12:07 AM
ZAP's Avatar
ZAP
Default Re: Speedbleeder on the clutch? (C-5 TECH)
got it. i have an auto and was not familiar with the m6 set-up. we put a speedbleeder on the race car but on our car you can reach the throw out bearing thru a hole in the bellhousing :cheers:
Old Dec 10, 2001 | 12:35 AM
ZO6LS6's Avatar
ZO6LS6
ZAP, buy a battery suction bulb, and a couple of cans of Valvoline Synpower.......suck out the old, wipe out the resevoir........and fill er' up......repeat as often as neccessary........(this remedy to clutch issues brought to you courtesy of Ranger)..........
As soon as the fluid starts turning DARK, get it out........it's is fried......... :mad :eek: :rolleyes:
[Modified by ZO6LS6, 4:36 AM 12/10/2001]
To Speedbleeder on the clutch?
