reverse lock out solenoid
Old Mar 18, 2008 | 09:11 PM
twobit's Avatar
twobit
Default reverse lock out solenoid
.this topic has been discussed quite a bit about shifting from 4th into 5th and going into reverse insted.where is the solenoid and the wiring.do you need to pull the tranny.my 03 z seemes to be doing this more and more.i am being told it is a lot of money to have it replaced.
Old Mar 19, 2008 | 12:08 AM
backnblack2003z06's Avatar
backnblack2003z06
I did mine about a year ago, it is located on the driver side of the trans. There is a special GM socket that fits over the solenoid. I used that and a stubby flex head 3/8 drive ratchet and it came right out, took all of 15 minutes.
Old Mar 19, 2008 | 09:45 AM
Plasticfan's Avatar
Plasticfan
My 02 Coupe has done that a time or two. Is solenoid replacement the first thing to try or are there some other checks to be made? I have no codes. Can it be done w/o the special GM tool? What does the solenoid cost?
TIA
Old Mar 19, 2008 | 10:08 AM
twobit's Avatar
twobit
so you dont need to pull apart the tranny?the selinoid is on the out side of the tranny.can you get to it if the car is on a lift?how much is the selinoid?
Old Mar 19, 2008 | 10:14 AM
timemender's Avatar
timemender
Best price (MUCH less than dealer price) can be obtained from CorvetteForum vender Gene Gulley
His business is "GMPARTSHOUSE.COM" Phone 610.862.0550
Genuine GM parts.
Old Mar 20, 2008 | 01:15 AM
backnblack2003z06
Yeah its on the outside of the trans, the special tool allows you to get the solenoid out with little problem its a pretty big size socket.
To reverse lock out solenoid
