Leaking Oil Temperature Plug/Sensor?
Old Mar 18, 2008 | 09:59 PM
RrCoX22's Avatar
RrCoX22
Default Leaking Oil Temperature Plug/Sensor?
Has anyone else had this sensor/brass fitting leak oil? I pulled it off and it seems that the metal ring is perfectly fine and during inspection it seems that there's nothing wrong. I know this is the source of the leak as I started it up and oil was clearly dripping out ...seems to be leaking in between the metal casting and the brass fitting.
