P0135, P0155
Old Mar 20, 2008 | 03:08 PM
vettekidc5's Avatar
vettekidc5
Default P0135, P0155
P0135 Heated Oxygen Sensor (HO2S) Heater Circuit Bank 1 Sensor 1
P0155 Heated Oxygen Sensor (HO2S) Heater Circuit Bank 2 Sensor 1
Im Having a Issue with these two similar codes, They are the Heated oxygen sensor circuit for bank 1 and 2.
i dont have rear o2's They have been tuned out.. Long story short, I have a new engine, and somehow allong the way my wires got burned on the headers after I installed it..
I repaired the plug to the best of my knowledge it looks fine . The other side is pretty much undamaged yet Im getting the same code over on bank 2.
Does the both bank 1 and bank 2 oxygen sensors have some sort of intergrated heater citcuit that may be the fault?
Old Mar 20, 2008 | 03:54 PM
jirasvet's Avatar
jirasvet
I could type out a lot of stuff, so i will make it easy,
since you burned the harness check o2 sensor fuse,
than read this
http://www.gearchatter.com/viewtopic10710.php
Old Mar 20, 2008 | 07:50 PM
BIG ATLANTA's Avatar
BIG ATLANTA
I just had the same problem $770 dollars later I found it was the fuse #15 in the fuse panel at the battery 15 amp mini fuse
Old Mar 20, 2008 | 11:10 PM
vettekidc5's Avatar
vettekidc5
yeah I checked it before anyone responded... the Fuse was blown, Replaced it and all appears welll..
Old Mar 21, 2008 | 11:21 AM
jirasvet's Avatar
jirasvet
Old Mar 21, 2008 | 02:02 PM
BIG ATLANTA
Thanks for the posting the solution!!!
Old Nov 23, 2008 | 03:10 PM
MadDogZ06's Avatar
MadDogZ06
Default Dtc 135 155
than read this
Thanks guys!!! You just saved me a huge hassle. Thanks for posting this. My fuse was blow as well. I am overdue for inspection and I have been putting off debugging these codes. Awesome.
MadDog
To P0135, P0155
