Water Pump
Old Mar 20, 2008 | 10:55 PM
Jamn's Avatar
Jamn
Default Water Pump
It's been a while since I've been on this forum, but I do need some help at this time. I have 55k miles on my 01 coup, and it seems that my water pump is leaking at the shaft. I can get one at Pep Boys for about $133.00. Does anyone have instructions posted on the replacement procedure, and is this a tough job?
Old Mar 21, 2008 | 02:00 AM
BlackZ06's Avatar
BlackZ06
Pretty straightforward procedure ....
* Remove air bridge from throttle body and position out of the way.
* Remove serpentine belt
* Drain coolant from radiator (or expect coolant coming out as you disconnect hoses)
* Remove large Inlet and Outlet hoses from water pump
* Remove Heater Inlet and Surge Tank outlet hoses from water pump
* Unbolt water pump
* Remove
* Remove water pump gaskets
-------------------- Installation
* Install water pump with gaskets to engine
* Hand start water pump bolts
* Tighten bolts in 2 passes (11 lb/ft first pass then 22 lb/ft second pass)
* Reattach 4 hoses
* Install serpentine belt
* Install airbridge to throttle body
* Fill coolant system with fresh coolant
* Open a 6 pack and
Old Mar 21, 2008 | 03:37 AM
Jamn's Avatar
Jamn
What sealant do you use between the waterpump and the heads,,Silicone?
Old Mar 21, 2008 | 04:24 AM
BMERETR's Avatar
BMERETR
Keep The Shiny Sine Up
gaskets have seals built in
you might want to use some gasket tack
to help hold them while you get the bolts started
it helped me
Old Mar 21, 2008 | 07:57 AM
Cajundude's Avatar
Cajundude
Active Streak: 90 Days
Cruise-In 7-8-9-10 Veteran
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
No sealant used, install as stated above. Very easy job.
Old Mar 21, 2008 | 08:32 AM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
Note the new water pumps have a built in stat. When I did the one on the 02 I could not use my aftermarket stat. At least that was my experience. Also Gene Culley had the best price I could find at the time
Old Mar 21, 2008 | 08:34 AM
Cajundude's Avatar
Cajundude
Yo' Pewter, the new pumps are like the LS2. You can get a stat from SLP or Lingenfelter (off the top of my head).
Old Mar 21, 2008 | 08:40 AM
pewter99's Avatar
pewter99
Cajun....we needed the whole pump....had a 160 stat in the car ..couldnt use it in the new pump.
No biggie......... install was cake and the car runs perfectly and I ain't pulling it out to swap a stat
Old Mar 22, 2008 | 08:48 PM
Jamn's Avatar
Jamn
Anti-Sieze on the bolts right??
Old Mar 23, 2008 | 03:30 AM
Jamn's Avatar
Jamn
One more question.. After I get everything back together, how do I fill the radiator? It seems taht the recovery tank is the only inlet, and I dont see how filling that will fill a dry radiator....
Old Mar 23, 2008 | 09:28 AM
Cajundude's Avatar
Cajundude
That is correct, through the reservoir. Keep an eye on the level. You will need to let the car run and when the thermostat opens you will need to add some more coolant and you will probably have to burp the system a couple of times.
Old May 4, 2008 | 07:36 PM
pat03z06's Avatar
pat03z06
Thanks for the write up. I just did mine and it was a piece of cake
Old May 4, 2008 | 09:38 PM
gpracer1's Avatar
gpracer1
I fill them through the top radiator hose since it is already off. When coolant starts to come out of the waterpump fitting, then put the hose on and fill the rest through the tank.
To Water Pump
