Engine Codes: Should I worry about these?
Old Dec 9, 2001 | 11:16 PM
Wt99C5's Avatar
Wt99C5
Default Re: Engine Codes: Should I worry about these? (Travis99C5)
Thanks for the procedure on how to pull up the codes.
I just gave it a try and sure enough I have the same codes and a few more.
It will be interesting to see what the guru's have to say.
Old Dec 9, 2001 | 11:20 PM
vetteshop's Avatar
0vetteshop
Former Vendor
St. Jude Donor '13
Default Re: Engine Codes: Should I worry about these? (Wt99C5)
All those are normal software "glitch codes"...For the seat code,make sure that the 6 way adjuster works in all positions to the full travel...
You can also check the codes while running ;)
Old Dec 10, 2001 | 12:47 AM
ZO6LS6's Avatar
ZO6LS6
Default Re: Engine Codes: Should I worry about these? (C-5 TECH)
Hey C5..........Do you need 3 hands????????? :D :D :D
Old Dec 10, 2001 | 11:47 AM
5150 BRD's Avatar
5150 BRD
Thanks. Didn't know that.
Old Dec 10, 2001 | 01:17 PM
Gary2KC5's Avatar
Gary2KC5
Default Re: Engine Codes: Should I worry about these? (5150 BRD)
I got the SCM codes and sometimes when I unlock the doors with the remote it will raise the pass. seat all the way up.
this doesn't seem right...is this something to be concerned with?
Old Dec 10, 2001 | 01:50 PM
carpe dm's Avatar
carpe dm
Have Mr. GW check out the "B2" codes. :yesnod: :)
Old Dec 10, 2001 | 02:28 PM
Black_Magic's Avatar
Black_Magic
2020 Corvette of the Year (appearance mods)
C2 of Year Winner (appearance mods) 2019
CI 4-5-7-9-10-11 Car Show Winner
CI 2-3-4-5-6-7-9-10-11 Vet
Here is some additional help on how to get code and what they mean
http://home.att.net/~jansseng/DTC_Codes.htm
To Engine Codes: Should I worry about these?
