When I purchased my 1999 C5 used three years ago, I believed it had been lowered,(sate about 4 inches from groud), it sate lower than most corvettes that I have seen and looked nice. Last year my car began to get lower and lower to the point that the air dame would scrub the ground at the lowest of bumps and sits about 2 inches from the ground now. Could this be the leaf spring going bad or front shocks?
I'm not a suspension "expert"...but, your thinking is probably accurate.
You didn't mention the type of suspension you have (options) or your current mileage. Has the ride suffered with the loss of static height?
More than likely, it's the shocks on your car. You can usually find good deals on Z06 shocks in the CF classifieds. Try to find some '04 Z06 shocks and change front and rear for the best results.
There's also after market, which most seem to prefer BILSTEIN, but there are different versions, so wait for the "experts" to reply.
You might gain some information from this post... http://forums.corvetteforum.com/show....php?t=1978036
One other thing to check, before you start tearing the suspension apart, is tire pressure. These cars have really stiff sidewalls, and you can't always tell when the tire pressure is getting low... that can have more of an effect on ride height than you would think.
The suspension is stock, it just has the ride adjust option, I looked at the leaf spring bushings and they look good. The ride is still good, not that I take corners at high speeds. I have hit some bumps over the summer including a raised slab on the freeway. Are the shocks gas filled and could that have caused the problem? But I tell ya, the car looks really good the way it sits but I am scraping the front nose a lot.
The shocks do not hold the car up and you don't adjust the ride height at the shocks, this is all done at the adjuster bolts on the springs. If your car is lower and the adjuster bolts and bushings have not moved then your springs are starting to give.
If the gas or oil have leaked from the oem shocks, the static height may suffer. He stated above he has the ride adjust option. I'm not familiar enough with it, but if that is failing, wouldn't that possibly be a possible reason for loss of static height?
I do believe that this could be the leaf spring but I wanted to be sure because shocks cost much less than a front leaf spring. Most of the posts about bad leaf springs involved splintering or breakage, my springs look great. The car has 56K miles on it and I will need to change the shocks at some time but the main thing before I put it back on the road for Spring is to get the car off the ground. When I talk to the dealer they are very vague in there diag$$$$$$$$$$$.
runamuk is correct. The leaf springs control the ride height. The shocks are for controlling suspension travel and ride. If the springs are loosing tension then they would cause the body to drop. Why not just tighten the bolts up and see if you can raise the back up enough to get some more clearance before you do anything else?
Shocks only dampen the bound and rebound of the car. You can push them down with your hands when they are off the car.
