Tire size Question
Old Mar 26, 2008 | 09:25 AM
9secnotch's Avatar
9secnotch
Default Tire size Question
Does anyone know if there is a standard ratio to rpm drop or gain when changing the tire heights?
Im running a 26" tire with a set of 390 gears in a c5 and im trying to find out how many rpms i will lose on a 28" tire through the traps. i was told there is a standard ratio to figure that out.
Old Mar 26, 2008 | 11:56 AM
Toque's Avatar
Toque
From: Wylie TX --> Less is More, except under the hood !
Try this link:
http://www.rims-n-tires.com/rt_specs.jsp?
Input your curent rim sizes, and tire sizes.... then input your proposed sizes and it tells you all about the difference.
Toque
Old Mar 26, 2008 | 12:14 PM
robvuk's Avatar
robvuk
Easy. Changing from 26 to 28 is 28/26=1.0769 or 7.7% for a standard ratio in your situation. Divide your rpms by 7.7% or 1.077 to get your desired results. If you trapped at 5,000rpm before it will now be 5,000/1.077=4642
Old Mar 26, 2008 | 12:20 PM
9secnotch's Avatar
9secnotch
I trap at 6800 on a 26"..
Old Mar 26, 2008 | 12:30 PM
OhioDave's Avatar
OhioDave
St. Jude 15 Year Donor
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16'17-'18-'19-'20-21
Here's another calculator.
http://pw1.netcom.com/~sgalaba/mph.htm#GearSpeed
To Tire size Question
