fog lamps
Old Mar 26, 2008 | 10:14 AM
topless99's Avatar
topless99
Default fog lamps
what are the brightest lights ( non fog ) that can be used in the stock fog lamp location. im talking about just changing bulbs, nothing else.
Old Mar 26, 2008 | 12:12 PM
corvettebob1's Avatar
corvettebob1
I replaced mine with 885's they are 50W and make a significant difference.
Old Mar 26, 2008 | 12:39 PM
ALLEGRO's Avatar
ALLEGRO
885's and a re-aiming will make a huge difference.
Old Mar 26, 2008 | 03:27 PM
topless99's Avatar
topless99
who makes the 885
Old Mar 26, 2008 | 10:33 PM
ALLEGRO's Avatar
ALLEGRO
885 (50 watts) is the bulb number. 899's (37.5 Watts) are the stock replacement.
Here is a print-out from Sylvania for the C5:
Auto Lamp Replacement Guide - Results
Print out the list and find them at your nearest retailer.
2003 CHEVROLET Corvette
Low beam headlamp
9006
9006SU Silverstar ULTRA for Ultra Night Vision - The Whitest and Brightest Halogen
9006ST Silverstar High Performance Lighting: The Whiter and Brighter Halogen
9006XV XtraVision Halogen - The Brighter Light
9006CB Cool Blue Halogen - The Whiter Light
High beam headlamp
9005
9005SU Silverstar ULTRA for Ultra Night Vision - The Whitest and Brightest Halogen
9005ST Silverstar High Performance Lighting: The Whiter and Brighter Halogen
9005XV XtraVision Halogen - The Brighter Light
9005CB Cool Blue Halogen - The Whiter Light
Parking light
4157NALL
4157AST Silverstar Signal Lighting: Complete the Look: Crisp, Clean, Style
Front turn signal
4157NALL
Rear turn signal
3057
3057LL Long Life Upgrade: Up to twice the life of the standard lamp
Tail light
3057
Stop light
3057
High mount stop light
Assembly
Fog/Driving light
899
License plate
194
194LL Long Life Upgrade: Up to twice the life of the standard lamp
Back up light
2057
2057LL Long Life Upgrade: Up to twice the life of the standard lamp
Front sidemarker
194
Rear sidemarker
194
Glove box
194
Map light
212-2
Step/Courtesy light
194
37
Trunk/Cargo area
PC168
Under hood light
561
Instrument-general
194
Automatic transmission indicator
194
________________________________________ ____________
The applications presented in this replacement guide have been compiled using the best information available from the vehicle manufacturers at the time of your search. This guide is intended for general information purposes only, not to be construed as any type of warrantee as to any particular application. For specific applications the vehicle owner's manual should be consulted.
Old Mar 26, 2008 | 10:44 PM
rws.1's Avatar
rws.1
I used 885's for a year... a nice upgrade.... i was happy until a club member installed HID fog lights...
Guess what i installed this winter.....
Old Mar 26, 2008 | 11:51 PM
jdmvette's Avatar
jdmvette
Night Owl for life
HIDs are the brightest and are just barely more effort than a bulb swap.
Old Mar 27, 2008 | 07:42 AM
Junkman2008's Avatar
Junkman2008
They are so bright, that I adjusted mine slightly up and use them as headlights. I've went past a bunch of cops (plus I live across the street from the police station) and none of them have looked at me twice.
Old Mar 27, 2008 | 10:57 AM
fixvet's Avatar
fixvet
Be sure to check out your model year on www.sylvania.com since there are different bulb numbers for some of the C5 model years.
Old Apr 2, 2008 | 02:27 AM
ericshu's Avatar
ericshu
Help me with this. What brand do you do this with.
I have a 00 with fog lamps and want to do the same without a major hassle. It sounds like a plug and play thing...
Old Apr 2, 2008 | 10:29 AM
borkg2006's Avatar
borkg2006
Ditto on the 885's. The one problem I've found with them is the stock 899's are rated at 1,000 Hour life and the 885's are listed at 200 Hours. A significant difference but I rationalize that the 30%+ increase in output makes up for it, even if they burn out sooner.
Old Apr 2, 2008 | 12:07 PM
ericshu's Avatar
ericshu
i am wondering if the extra expense for the after market hid are worth the extra effort?
Old Apr 2, 2008 | 12:12 PM
Junkman2008
Ain't nothing worth it once you see a HID light. Those stock light looks like **** compared to a HID bulb. Plus, the stock fogs are HID housings so they are actually made for HID bulbs.
Old Apr 2, 2008 | 02:04 PM
Bville-Bud's Avatar
Bville-Bud
St. Jude Donor '05-'06-'07-'08
How much effort was it to mount the boxes on the HID installs? There isn't too much room in that area and I'm wondering if it is a PIA??
Old Apr 2, 2008 | 02:40 PM
Junkman2008
It's only a pain if you try and do it with the headlight assembly in the car. If you remove the headlights, you got enough room for Rosie O'Donald to take a bubble bath in there. Look at the picture below (don't pay any attention to the captions, they were for something else).
You can see that I had plenty room to mount my ballast and then some.
Old Apr 2, 2008 | 03:43 PM
TheeMike's Avatar
TheeMike
Where did you get that kit and how much?
Old Apr 2, 2008 | 03:50 PM
Junkman2008
PM sent.
To fog lamps
